Old 27-06-2006, 11:24 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Nokia 6610 colors ! ! !
how many colors r supported by 6610 ??? so as 2 create wallpapers ...
coz dark colors appear black ...
ax3 is offline
Old 27-06-2006, 11:51 AM   #2 (permalink)
dattebayo
anispace's Avatar
Default Re: Nokia 6610 colors ! ! !
i think itz 4096 colours... but at lower resolution
anispace is offline
Old 27-06-2006, 12:05 PM   #3 (permalink)
tuxfan's Avatar
4096 colors, resolution 128x128.
tuxfan is offline
Old 27-06-2006, 01:36 PM   #4 (permalink)
ax3
ax3's Avatar
bt how 2 create a wallpaper with 4096 colors ???
ax3 is offline
Old 28-06-2006, 11:15 AM   #5 (permalink)
tuxfan's Avatar
You don't need to change colours of an image. 6610 will take care of it
tuxfan is offline
Old 28-06-2006, 04:48 PM   #6 (permalink)
ax3
ax3's Avatar
any idea ...
ax3 is offline
Old 28-06-2006, 04:57 PM   #7 (permalink)
montsa007's Avatar
visit nokia.co.in
use any freely available image resizer to resize images xactly
montsa007 is offline
Old 28-06-2006, 06:53 PM   #8 (permalink)
any idea ...
Well.. i think digit fora is now getting dumb as most of the old players do not visit anymore ..
You AX3 got 690+ posts and your question suggest as if you know computer from only 1 months or so..
Well no hardfeeling,
just choose any picture in computer and then using any image editing program, resize it to something near to 128x128 and transfer it to phone. you can do that bye IrDA or by data cable. (both are supported by 6610).
Hope that was not hard.
Enjoy~
Ricky is offline
Old 29-06-2006, 01:21 PM   #9 (permalink)
ax3
ax3's Avatar
bt still u havent ans my ?
wallpaper with 4096 colors ... with photoshop ...
ax3 is offline
Old 29-06-2006, 10:06 PM   #10 (permalink)
aryayush's Avatar
Why do you need to limit the image's colours to 4096 before transferring it?
aryayush is offline
Old 29-06-2006, 11:59 PM   #11 (permalink)
The Devil's Advocate
iMav's Avatar
ax3 bhai hindi samjhaun toh aisa hai ki aapko image ke color kam zada karne ki koi zarurat nahi hai nokia's phone are intellegent and will take care of it ...... u dont need to do anything to the colors and as far as photoshop is concerned under the 'image' section on the toolbar u have 'mode' and 'adjustment' controls for changing the colors
http://beingmanan.com
iMav is offline
Old 30-06-2006, 10:54 AM   #12 (permalink)
well.. well.. I am laughin out loud here . Well, you can use any wallpaper even if trillians of colors but phone will show only 4096 colors, its similar to B/W TV where you are watch everything B/W .
Ricky is offline
Old 30-06-2006, 12:49 PM   #13 (permalink)
ax3
ax3's Avatar
bt whots the use of trillion or zillion colors if they dont showup ...
my ? was 2 get a preview of wallpaper with 4096 colors ... so as 2 avoid transfer - delete process on phone again & again ...
ax3 is offline
Old 30-06-2006, 05:48 PM   #14 (permalink)
tuxfan's Avatar
I think ax3 you are asking silly questions!! Just transfer it your cell and see it!
tuxfan is offline
Old 30-06-2006, 06:19 PM   #15 (permalink)
iMav's Avatar
well ax3 i will give a suggestion as silly as your doubt ........ go buy a new n93 ....... no need to worry about the colors
iMav is offline
Old 04-07-2006, 10:09 PM   #16 (permalink)
champ_rock
champ_rock's Avatar
well try the nokia pc suite... it has a image install application which customises ur image according to the model...
Registered Linux user number 400618
champ_rock is offline
Old 05-07-2006, 10:26 AM   #17 (permalink)
nik_for_you's Avatar
what is going on yar ... thats stupid ..
I AM REBEL
nik_for_you is offline
