| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Here is the step by step tutorial for inscresing any mobile battery life . This is my self tested tutorial and its works ....... STEP 1 :- Discharge your mobile battery to its maximum .>>>>>Whenever the mobile battery discharge then Mobile automatically turns off but even mobile battery has some charge and mobile can turn on [lights] but it again turnoff ,so the main thing is to discharge it so that mobile even cannot be TURNON. The battery should be discharged such that THERE IS NO BATTERY IN THE MOBILE(but there should be battery in the mobile). STEP 2:- Keep the battery as such for one or two days (whatever you wish to). STEP 3:- Now Charge that battery , you will find that its taking more time to charge . Charge it full and start using it, you will find that battery life has inscreased.... GET DISCHARGING SOFTWARE HERE http://rapidshare.de/files/22389350/...eware.zip.html |
#2 (permalink) |
Keeping a mobile off for 2-3 days is not practical guy. I wanna know if its healthy to do some cross connection on its terminals after removing it??It might be the fastest way to do that. If yes then which terminals are to be opted for a nokia battery like BL4c or 5c??
G1: PII X4 B50 4.0 | TRUE 120*2 | TA790GXB A2+ | 4GB DDR2 GSkill 1200 | Audigy 2 | HD4870 | HEC 550 | MX 518. G2: AII 240 | M2N 68AM+ | 3GB| 8800GT | Zebby Plat 500 G3: XPS M1530 | FZ 16. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
