Hi,
well using file explorer is one of the good way to delete those unwanted installations, but as per JRSCs problem, the manager is not at all showing the files, that means there is some problem in his software or something like that, so better i suggest the soft re-set.
@JSCR : Dont forget to make a back up while reseting to the original factory settings.
alternately, (just to Check)
remove yout MMC, then try to run the manager, just check whether still it shows the same problem or ....
if it still shows the same problem, then format the phone to original setting, but if it is working perfectly, then as suggested by MONSTA007, try Fexplorer or any other File manager.
please mail me at
joshi_ban@yahoo.com for fexplorer
