03-06-2006, 12:46 PM
Firmware Request
Firmware upgrade for Nokia 6630 available in India.i heard latest firmware released for N6630 let me how to do it.
03-06-2006, 10:27 PM
18 Till I Die............
Re: Firmware Request
You can check it at Nokia Care shop. They will do the upgrade free if your phone is still in warrany period.
04-06-2006, 04:34 PM
I got a 6630 5-6 weeks back. Are you sure the new firmware is launched. Could you please give more details.
04-06-2006, 11:01 PM
what actually happens after upgrading the firmware of your mobile..... where it is done. can it be done from home..?
04-06-2006, 11:38 PM
Every feature is same after upgrade .. new firmware is done for better support n working of the cellphone
With 99.9% certainty that after that you can throw you phone in dustbin.
firmware update require seperate hardware ..why spend wen it can be done for free at any Nokia Care Centre
05-06-2006, 09:41 AM
Hey mobilegeek Please be more specific. Can you tell me where is Nokia Care Centre in Kolkata. I wanna inquire and if possible get it upgraded.
But whats the advantage of upgrading????
05-06-2006, 10:58 AM
buddy firmware upgrade means bug fixes ur fone is more smooth
and no it cannot be done at home u need the cable (not the data cable) its like a matchbox plugged in ur battery and somethin is done and voila its done ur fone is upgraded
maharajadhiraj
u got a new phone .. u are askin.. for firmware upgrade
IS THERE ANY PROBLEM IN YOUR CELL ??
FIRMWARE is reinstalled if .. there is a problem & a bug is fixed.. not otherwise.
its like drivers...u dont need one evryday & newupdates are rare
Press *#0000# to know the software version of your phone
u dont need to worry .. it should be something 5.03.xx
mine is 4.03 & its working fine
05-06-2006, 10:59 AM
no buddy it is always good to keep ur fones firmware upgraded
05-06-2006, 11:20 AM
I am not sayin that .. but people take it as something ki .. it will add some new software or feature to phone .. thats not the case.
in his case he got a new phone .. if its working fine there is no need for that. isnt it.
I get my ph updated .. only If i get time .. which will not be soon.
05-06-2006, 11:31 AM
And yes ...
The latest version of 6630 is 6.03.08, but I dont think its available here.. they are lazy .. If anyone got post here.
b4n
05-06-2006, 02:41 PM
I pressed *#0000# and here's what it showed
v 5.03.08
17-08-05
RM-1
Nokia 6630
06-06-2006, 12:40 PM
buddy firmware cannot be upgraded at home and dont risk ur mobiles life by doin so
07-06-2006, 01:02 PM
OK OK that was just a question man. one more thing will all my data be lost if i upgrade my firmware through nokia care. or it can be backed up and restored easily.
07-06-2006, 02:11 PM
Phone memory will be deleted ..
MMC will be safe .. they will give u the mmc
Yes you can take the back up ..
1st .. go to contacts>options>copy to mmc
2nd .. inbox ..> options>other>memory in use>mmc
And 3rd .. Go to Organiser>MemoryCard>options>Back up phone memory
You are done
08-06-2006, 11:39 AM
yes dude but when u reset the fone memory all apps installed in ur mmc are useless i installed profiexplorer(cracked) on my qd
then pressed *#7370#
then when i opened the profiexlorer it restarted my fone
"in short a home made virus 4 ur cell"
10-06-2006, 10:28 AM
Nothing happens to anything installed in mmc
12-06-2006, 10:10 PM
#19 (permalink)
No Offence To Above Moble Geeks .if You Dont Know What Is Firmware Then Dont Speak About It.
Firmware-it A Virtual Host Environment Used On Series (60,70,90....)
And Many Symbian Based Cell Phones
It Can Be Easily Upgraded By Using Just Your Data Cable ,and A Software Named Phoneix(with The Mobile Firmare ) Which Can Be Easily Fetched Online
CHILL OUT AND HAVE FUN
13-06-2006, 11:16 AM
#20 (permalink)
Searching...
@ montsa007
Firmware can DEFINATELY be upgraded at home... i had moto E398 and i had upgraded it firmware at home only .. and it does not need separate hardware jus a USB cable, some software and the firmware ... Thats all !!!
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
13-06-2006, 09:30 PM
#21 (permalink)
Yeah....
I too updated the firmware of my SE W800i at home without any hassle.
Wonder if it's the same with the Nokia handsets....
Simple things are to simple too understand.
14-06-2006, 09:02 AM
#22 (permalink)
Nokia Phones firmware cant be updated without a special box AFAIK and the firmware files of nokia r not openly distributed.If yes give me the link.It can be done on moto phones(firmware can be downloaded from their website) and installed by data cable.Nokia Care do hv the latest versions available for flashing.
For Latest Firmware check http://www.ade.cz/verze_sw.htm
14-06-2006, 09:52 PM
#23 (permalink)
the list is old
and i have updated my nokia 7610 at home using usb cable
15-06-2006, 01:29 PM
#24 (permalink)
Originally Posted by popper1987
the list is old
hay buddy, i also want to change my firmware for nokia 6600 and 6680, can u please tell me how and where can i get the softwares!!!
May god's Blessing always be with you
15-06-2006, 05:14 PM
#25 (permalink)
you have find a software called phoneix and the firmware of your cellphone (can bet fetched at iphone website).for details give me your email id
15-06-2006, 06:24 PM
#26 (permalink)
@popper
hay my email id is joshi_ban@yahoo.com, please tell me how and where can i fetch the new firmware and how can i install in my n6600 and 6680
15-06-2006, 09:52 PM
#27 (permalink)
Some info I found on updating Nokia cell phones
What I need :
Drivers
FLS-4 Drivers
Software
PhoenixBlackBox_v7.0
Phoenix
Wintesla
Installation Steps :
Drivers
Run FLS4207.Drivers with PBB2 not connected.
PowerOn Your PBB2 ( I used 7.5v and -(°+ Polarity. )
Insert USBCable ( male-male ) on PC and then in PBB2
System will start searching drivers for installation... let system do that for You
wait ... there are some drivers to install, so be patient.
when complete system will tell You new hardware is ready.
Now You can start BlackBoxTool and see how Your PPB2 is configured.
Now You can "GO Support" and download what You need.
Note: - PBB2 here stands for Phoenix Black Box 2.
<snip> anything ahead will be illegal
this shows that just USB cable isn't enough.
I am not a expert or something at this. Can anyone who has more knowledge give more information.
BTW, I can't show the source as it is an illegal link.
16-06-2006, 05:33 PM
#28 (permalink)
the list is old
The list is updated.Check the update date.
17-06-2006, 02:44 PM
#29 (permalink)
What I need :
Drivers
FLS-4 Drivers
Software
Phoenix
Wintesla
Drivers
PBB2 is box that is used to flash nokia and other phones.It costs few hundred USD.
But if u hv a Nokia BB5(3250,6630,6680,6681,N70...) u can update the firmware with the supplied dku-2 or ca-53 cable.heres the link http://howardforums.com/showthread.php?t=913725
17-06-2006, 05:44 PM
#30 (permalink)
Hmm thanks mayhem.
I don't really know much about this but I'd like to know more on this topic. Let's see what more info I can collect.
So, it seems it is possible but you should be careful or you will have a very expensive piece of brick in your hand.
