Originally Posted by chaan
Is it possible to transfer data from Nokiya 6600 via data cable? how? The Standby time of Nokiya 6600 is 24 hrs only in real life situation where the manual says it is 240 hrs.?
as far as I know nokia 6600 does not hav any pop port so date cant be exchanged with DKU cables...but there are cables that would let u connect a 6600 via a firmware port (risky and absolutely not recommended ).So normally u can exchange date only through ir or bt. Those cables cost around 200 rs. search e bay and u will find it there
On the second q the standby time depends on varoius factors such as usage type,network strength,sim ccard etc.
Camera,Bt gprs consumes battery fast so if u use them dont expect good standby time.
But still for a person with avarage use of all features the battery should last for at leat 2 days..so ur battery may be faulty
