Old 23-05-2006, 02:01 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Default bought the DCU-11 cable and connected to the K300i SE
When i plugged it to the USB port, it looked for the driver and told that it could find the driver for the USB-Serial Controller C.
I looked through the SE Global Area Support and downloaded the driver for the DCU-11 cable and tried to install the drivers manually,but still it says, 'cannot find the drivers'.
I'm not sure if i need to turn on anything on my mobile before i do a sync.
Please help.
Ace Ventura is offline
Old 23-05-2006, 01:08 PM   #2 (permalink)
montsa007's Avatar
Default Re: bought the DCU-11 cable and connected to the K300i SE
start it all over again
i mean remove all the drivers u installed 4 the fone and then plug in the cable and select computerised search am sure it can help
montsa007 is offline
Old 23-05-2006, 09:18 PM   #3 (permalink)
Hi whats the price of dcu11 cable?
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 23-05-2006, 11:09 PM   #4 (permalink)
hye
i paid Rs 260/- for the cable
Old 24-05-2006, 12:23 AM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
First run the installer of the cable, it'll store the required driver files into appropriate folders.
Then attach the cable to computer and windows will automatically install the drivers.....
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 25-05-2006, 10:55 AM   #6 (permalink)
navneeth_snr's Avatar
This is a common problem in DCU-11 as the bundled software in the cd will not work.
Just Install the cable drivers manually, then download Sony Ericsson File Manager from www.sonyericsson.com
OR
You can get the SE File Manager is some recent Digit CDs/DVDs.
You can also use My Phone Explorer instead of SE File Manager.
Navaneeth
My Phones: Motorola T180, Nokia 2600, SE J300i, SE W810i
navneeth_snr is offline
Old 26-05-2006, 11:37 AM   #7 (permalink)
HI may i know from where u bought dcu-11.?Is it original SE?
Thanks,
mandar5 is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/28747-bought-dcu-11-cable-connected-k300i-se.html
bought DCU 11 cable and connected to K300i SE Mobile Monsters Question This thread Refback 24-01-2011 05:05 PM
