Old 22-05-2006, 10:45 AM   #1 (permalink)
Smile How To Compact Mp3 Songs For Se550i
Please Any Body Can Tell Me How To Compact The Size Of Mp3 Songs While Using In Se 550i.
spremals is offline
Old 22-05-2006, 11:34 AM   #2 (permalink)
montsa007's Avatar
Default Re: How To Compact Mp3 Songs For Se550i
please use stream box ripper its simple and cool 1
montsa007 is offline
Old 22-05-2006, 12:30 PM   #3 (permalink)
Smile Re: How To Compact Mp3 Songs For Se550i
THANXS.... PLEASE SEND ME AS SOON AS POSSIBLE..ON spremals@gmail.com
spremals is offline
Old 22-05-2006, 12:39 PM   #4 (permalink)
deathvirus_me's Avatar
Just decrease the bitrate .. say from 128 to around 80 .. that should bring down the size by a lot ...
deathvirus_me is offline
Old 22-05-2006, 12:44 PM   #5 (permalink)
What Will Be The Effect On Sound Quality By Decressing The Bit Rates???
spremals is offline
Old 22-05-2006, 03:18 PM   #6 (permalink)
montsa007's Avatar
dude streambox ripper is freely available on the net use a google search and type "download streambox ripper"
Old 22-05-2006, 03:49 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Why not convert them into aac format using iTunes?
It'll save a lot space...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 22-05-2006, 03:51 PM   #8 (permalink)
montsa007's Avatar
dude not all fones play aac format u need a patch to play them and if u xchange dtuff wid blutooth 4get usin the aac format
instead stick to mp3 at 64 kbps
Old 22-05-2006, 04:09 PM   #9 (permalink)
Microsoft MVP
I always use Bluetooth to transfer aac songs into my SE K700i
And I never faced any problem....
Old 22-05-2006, 04:11 PM   #10 (permalink)
montsa007's Avatar
arey baba not all fones are ready to play aac format vishal bhai
Old 22-05-2006, 04:45 PM   #11 (permalink)
Aniruddh's Avatar
ohh man thanks a lot...streambox ripper eva helped me..da original file which was 5mb..is now 1.2 which is awesome..and sounds almost da same..gr8..thanks so much...can anyone temme how can i compact video files for my fone..SE Z530i...
Aniruddh is offline
Old 22-05-2006, 04:56 PM   #12 (permalink)
montsa007's Avatar
sorry boss video can be maximum compressed in 3gp format compressin them is hittin urself
Old 22-05-2006, 05:49 PM   #13 (permalink)
mAYHEM's Avatar
To get the best quality and small size use all2lame(or any other frontend for lame.exe).
I use these settings
-V 9 --vbr-new -m m -a -h --lowpass 20 --noreplaygain
use lowpass filter between 15 to 21 all the detail in the music will be preserved.
Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
http://www.speedtest.net/result/445135884.png
mAYHEM is offline
Old 22-05-2006, 05:50 PM   #14 (permalink)
aryayush's Avatar
But the threadstarter specifically mentions that he wants it for Sony Ericsson W550i and it supports AAC.
spremals, use dBpowerAMP Music Converter to convert and encode your audio files to the MP3 format at 64 KBPS. I do that and I get the best balance of quality and size. I have SE W550i too. There won't be any noticeable loss at 64 KBPS, you can verify it by listening to a 128 KBPS song simulaneously (i.e. one after the other, obviously).
Apart from iTunes, which software can be used to convert audio files to AAC format?
aryayush is offline
Old 22-05-2006, 06:19 PM   #15 (permalink)
mAYHEM's Avatar
DBpowerAmp can be used for AAC also.I use HE-AAC and VBR MP3 for listening to music on my N3230
mAYHEM is offline
