Old 20-05-2006, 07:48 AM   #1 (permalink)
maharajadhiraj's Avatar
Default How to apply a theme in 6630
Hey guyz I recently downloaded some themes for my 6630. How do I apply them????
maharajadhiraj is offline
Old 20-05-2006, 01:02 PM   #2 (permalink)
D PrankMaster
prankie's Avatar
Default Re: How to apply a theme in 6630
first transfer theme onto ur mob...
open it.. u'll need to install it.
after installation goto themes (will be there on the mainmenu) select the theme, click apply or select preview if u want to see how it looks..
prankie is offline
Old 20-05-2006, 03:53 PM   #3 (permalink)
"open it.. u'll need to install it. "-Thats the problem, its not opening. How do I install it???????????????
Old 20-05-2006, 04:04 PM   #4 (permalink)
D PrankMaster
prankie's Avatar
strange!!!!!
maybe the theme is corrupt.. btw any error???
prankie is offline
Old 20-05-2006, 05:26 PM   #5 (permalink)
Most probably the themes r corrupt,otherwise opening the file starts installing,as in my 6630.
Najesh is offline
Old 20-05-2006, 09:34 PM   #6 (permalink)
I've transferred at least 20-25 themes (.sis format). None are working. Its showing a red icon in each of them. Nothing happens when I select them. No, I don't think the files are converted. Is there anything wrong with my mobile??
Old 20-05-2006, 11:49 PM   #7 (permalink)
D PrankMaster
prankie's Avatar
red icon????
if possible plz post a scrn shot..
prankie is offline
Old 21-05-2006, 08:39 AM   #8 (permalink)
From where did u opened the theme sis file?
Try opening it from the file manager. let us tell the results
!! www.khin007.com !! the technology portal
khin007 is offline
Old 21-05-2006, 09:22 AM   #9 (permalink)
@ khin007
I stored my themes in a separate folder in Organiser/File Manager/Memory Card/Themes. It shows a red icon and nothing happens when I select it. I'll just send the scrrenshots in an hour or so.
Old 21-05-2006, 09:53 AM   #10 (permalink)
I couldn't exactly get the screenshot but I have created a bitmap image of how it looks. Check it out:-
Old 21-05-2006, 11:30 AM   #11 (permalink)
D PrankMaster
prankie's Avatar
Question Re: How to apply a theme in 6630
Red icon!!!! never saw anything likethis before... if i'm not wrong, than u'r not able to install any sw too...right?
Dunno.. maybe prob with ur phone.
try formatting... if that doesnt help, than show ur phone to prioity dealer..
prankie is offline
