Old 19-05-2006, 12:02 AM   #1 (permalink)
D PrankMaster
prankie's Avatar
Question Setting up IM???
Can anyone help me to setup IM on my N3250...
when i start the programme it asks.
No server defined.Define one now?
i prss yes.
then it asks for-
Server name
Access point in use
Webaddress
User id
Password
plz tell what should i fill in the first 3 options..
i want to setup im for msn.
prankie is offline
Old 19-05-2006, 09:26 AM   #2 (permalink)
Default Re: Setting up IM???
U will have 2 contact the Operator ,it is Operator Service.
Najesh is offline
Old 19-05-2006, 12:27 PM   #3 (permalink)
D PrankMaster
prankie's Avatar
has it anything to do with the gprs settings????
I already have 'em...
prankie is offline
Old 19-05-2006, 03:35 PM   #4 (permalink)
No though u r having gprs like me,4 getting services like IM u will have 2 call the Operator,if they r providing it in ur region U can get it from them,and definitely few settings will have 2 b added for IM,but it will b told u by the operator itself.
Najesh is offline
Old 19-05-2006, 06:48 PM   #5 (permalink)
D PrankMaster
prankie's Avatar
But i used to use Agile Messenger on my N6600....
it worked flawlessly and
only Gprs connection was requred to run it... so why does this IM requires so many settings???
prankie is offline
Old 19-05-2006, 07:44 PM   #6 (permalink)
thrash_metal's Avatar
I Still use Agile messenger on my nokia 6670 .... works amazing ... always connect to both yahoo and msn !! What i have heard smtimes operators charge per message if they provide u a IM service from them , but Agile is thr GPRS for my plan is a fixed rental no matter how much i use .. so i use Agile
a good computer + a great gaming rig + a blasting music workstation + a recliner = LIFE !!!
thrash_metal is offline
Old 19-05-2006, 08:18 PM   #7 (permalink)
deathvirus_me's Avatar
U should enabled ur POP account first ... u should the server and access point from there ..... then just put them accordingly in ur im as required. .. and make sure ur gprs is active .....
I don't think u'll find Agile Messenger or IMPlus for 3250 .... that phone has so many good features .. but that S60 v3.0 OS9.1 is killing it ...
deathvirus_me is offline
Old 19-05-2006, 10:42 PM   #8 (permalink)
Thrash metal is right if u want 2 use softwares u can do i,but if u want 2 use features presnt in phone u will have 2 tak 2 operator.
Najesh is offline
