Old 11-05-2006, 10:54 PM   #1 (permalink)
LegendKiller's Avatar
Default How to unlock Nokia 6280??? plz help!
i just purchased n-6280,i am using hutch,plz tell me how and where to find its unlock code,i am told the service provider ie sim provider will tell u...plz tell me!
In the Pic: The Great Sachin Tendulkar
LegendKiller is offline
Old 13-05-2006, 05:24 PM   #2 (permalink)
sysmaniac
Posts: n/a
Default Re: How to unlock Nokia 6280??? plz help!
you have not mentioned which unlock key you want..??? If its a sim lock then u will be asked for PUK (Pin Unblocking Key) which u can get from Hutch Call Centre after providing details and SIM number (written behind the sim).
if it is a phone lock then you have to type 12345 (though its default). Or you have to flash your phone.
Check out google to flash phone.
Old 13-05-2006, 10:34 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
what is i forgot phone lock code of nokia 1100.what to do????
gary4gar is offline
