Old 10-05-2006, 04:07 PM   #1 (permalink)
Smile Smart Movie Doesnt Work Please Help
Hi there....
I have a N6600 and i have Smart Movie 2.50 installed.. For the last 1 week its givin me a whole lot of problems.
Whenever i play a song, it(SM) automatically exits after 12 seconds.. I m not able to c any song..
What cud b the problem??
Please help..
Thanks
Zeeshan
swades is offline
Old 10-05-2006, 04:24 PM   #2 (permalink)
montsa007's Avatar
Default Re: Smart Movie Doesnt Work Please Help
reinstall after removing the software
and properly install its codecs
if its a demo version i cant help u it has to close after some time
montsa007 is offline
Old 13-05-2006, 08:53 PM   #3 (permalink)
I tried reinstalling the software but to no avail..
Its givin me the same problem....
Please help...
Thanks
swades is offline
Old 14-05-2006, 08:12 PM   #4 (permalink)
try downloading it from somewhere else and re-install
!! www.khin007.com !! the technology portal
khin007 is offline
Old 17-05-2006, 12:32 PM   #5 (permalink)
gdatuk's Avatar
try using the latest version..u might get lucky
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 20-05-2006, 10:36 AM   #6 (permalink)
yup, the latest version will do the trick!
btw, what is the latest version? 3.12 / 3.13?
Samee is offline
Old 20-05-2006, 01:14 PM   #7 (permalink)
!FREEWARES!
Akshay's Avatar
Smart movie latest ver. is 3.12.
If u have tried installing another copy of smart movie which has given u the same error then it wud be better if you format ur cell.
I hope u have not messed around with the files using file explorers
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 23-05-2006, 09:57 PM   #8 (permalink)
1. this is the problem due to virus
install a latest antivirus and update your smart movie to 2.50 to 2.76 this will solve your porblem. smart movie 2.76 a series 80 platform software but u install in series 60 too.
jojoji_jojo is offline
Old 23-05-2006, 10:09 PM   #9 (permalink)
deathvirus_me's Avatar
v3.13 is out .... anyway .. make sure u remove all current records of the smartmovie via FExplorer ...
deathvirus_me is offline
Old 24-05-2006, 08:54 AM   #10 (permalink)
gdatuk's Avatar
3.20 version is now available...
Twitter @cgiridhar
gdatuk is offline
