Re: help me out with my l7
Hi buddy,
Me too bought a L7 a month back. although the mobile is great. there are some drawbacks though which i hope i will be able to solve myself by going to the above mentioned links.firstly while playing videos, half of the screen is covered by the controls, secondly the mobile does not open .jpg pictures having a resolution higher than 640 X 480 which is quite annoying . so i hope these problems will be solved by sticking with you guys.
until then ciao
lovemeall26
KNOWLEDGE SHARED IS ALWAYS FRUITFUL AS IT CAN BENEFIT YOU TOO ONE DAY. SO HEY GUYS LETS MAKE THIS A GREAT COMMUNITY TO SHARE IDEAS AND STUFF LIKE THAT,
CHEERS,
LOVEMEALL26
