Re: help!!!! how to connect to internet through gprs
I have been using airtel gprs for past 5 months at rental of Rs.150 only. Airtel Live is different from Airtel GPRS. Accessing Airtel Live is free but for
anything u download u have to pay. Also Airtel Live lets u access only Airtel Live portal and no other site.
Airtel GPRS lets u access any poss. site using the rite s/w. (like Opera).
For Airtel GPRS configuration, follow these steps..
First of all u dont need any 3rd party s/w. to access internet using Airtel GPRS (for Win XP pro with or without service pack2)
After you receive settings from Airtel, configure the settings for ur computer... Install ur bluetooth modem drivers. If u have not received any drivers, try downloading Widcomm bluetooth drivers from the net.
Create a network connection from control panel with bluetooth as ur modem.
For dial up no. use - *99# or *99***1#
Always keep the User name and password field blank
If this doesnt work, den try:
Go to Control panel - phone and modem settings - Modems tab - select Bluetooth modem - advanced tab -
In extra initialization commands, type: AT+CGDCONT=1,"IP","airtelgprs.com","",0,0 (there are no spaces in between)
This should help u...
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
