Old 03-05-2006, 12:17 AM   #1 (permalink)
Default nokia with mp3,cam,fm radio
i m lookin for a handset which has an mp3 player, camera ,fm radio and bluetooth......worth >10,000..... if not all the above features atleast any 3 of the features must b there like... mp3 player,cam,fmradio or anyother combination..... which one should i go for?
shay4u is offline
Old 03-05-2006, 12:41 AM   #2 (permalink)
Default Re: nokia with mp3,cam,fm radio
nokia 6600 comes with 3 features except that fm radio under 10000..........
but if u want the fm radio also go for nokia 3530.........
but the cost will be little bit more........
dharmeshhtailor is offline
Old 03-05-2006, 12:59 AM   #3 (permalink)
dIgItaL_BrAt's Avatar
u could consider the Nokia 6230.
It's got all the above features and it's < 10,000
dIgItaL_BrAt is offline
Old 03-05-2006, 01:01 PM   #4 (permalink)
montsa007's Avatar
6260,3230,nd k700i?
don opt 4 6230
montsa007 is offline
Old 03-05-2006, 01:28 PM   #5 (permalink)
Gunner's Avatar
If you want a huge combo like that, you can always go for the N-Series. N70 is good with all that and retails around 19000. Go on EMI basis and it'll be reasonable. You said >10000 right ?
Gunner is offline
Old 03-05-2006, 01:54 PM   #6 (permalink)
D PrankMaster
prankie's Avatar
Nokia 3250...
has all the features u mentioned.. and looks cool too....
i have it... it'll cost u 18500INR
u can also go for N70... and i think it must be cheaper than N3250..
prankie is offline
Old 03-05-2006, 01:55 PM   #7 (permalink)
montsa007's Avatar
i think he has a limited budget or an unlimited 1 plz do specify that buddy
if unlimited u can choose 3250
Old 07-05-2006, 09:52 PM   #8 (permalink)
prasad_den's Avatar
If your budget is >10K, then you can go for any high end mobile....!! Also give your upper limit buddy, coz there are thousands of models out there..
prasad_den is offline
Old 10-05-2006, 09:59 AM   #9 (permalink)
montsa007's Avatar
u can go 4 the newly launched w300i
and wat abt se w520i its same as k700i but has xpandable memory @ 8300/-
lacks radio but everything else is present
