Old 26-04-2006, 07:54 PM   #1 (permalink)
Searching...
Default Motorola L6 help !!
Guys i recently bought a moto L6... the pro is that when it plays video most o the space is taken by the controls .... is there any sft to make it full screen... also guys do you know the site or have its sft upgradation..?? THX
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 29-04-2006, 05:21 PM   #2 (permalink)
Default Re: Motorola L6 help !!
Hi buddy,
I also bought a moto L7 and am facing the same problem, half of the screen is wasted, also it is not displaying jpeg pics having having a resolution of above 640 X 480. Does ur L6 display such jpeg's ? I have asked for my vendor to get me the softwares to remove both these probs, once I get them I will try to send it to you ok bro, until then, bye and all zee best
lovemeall26
KNOWLEDGE SHARED IS ALWAYS FRUITFUL AS IT CAN BENEFIT YOU TOO ONE DAY. SO HEY GUYS LETS MAKE THIS A GREAT COMMUNITY TO SHARE IDEAS AND STUFF LIKE THAT,
CHEERS,
LOVEMEALL26
lovemeall26 is offline
Old 01-05-2006, 02:23 PM   #3 (permalink)
prasad_den's Avatar
Video playback layout for the Moto E398 is the following:
Size ------------------------- Layout
Sub-QCIF 1 (small) ----------- 88x72
Sub QCIF 2 (medium) --------- 128x96
Full QCIF --------------------- 176x144
It has to be something similar for L6 and L7.. And I don't think its possible to have full screen display for video playback, even using other 3rd party softwares...
prasad_den is offline
Old 06-05-2006, 07:41 PM   #4 (permalink)
thanks a lot prasad_den, hope u keep us posted on such stuff, also would be highly obliged if you could explain the .jpg problem too. meanwhile , i found lots of softwares and games at www. getjar.com try it amol48. bye
CHEERS,
LOVEMEALL26
Old 06-05-2006, 09:05 PM   #5 (permalink)
phatratt's Avatar
I have a moto L6,i don't know if there is any java apps to make it play it full screen.
@lovemeall26,u can't go beyond 640X480,remember it has a VGA cam not a megapixel monster.the phone can capture a max of 640X480 res pics.
@prasad den,plz let us know if u know any apps and give us links for download.Thanx.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 08-05-2006, 06:38 PM   #6 (permalink)
Hi phatratt, i do understand that it has a vga camera and that it takes pics upto 640 x 480 only. what i meant was when i upload my pics from my computer having higher resolution, thats when it does not open. i just wanted a software that can open .jpg files larger than that resolution, thanks
CHEERS,
LOVEMEALL26
Old 08-05-2006, 09:23 PM   #7 (permalink)
phatratt's Avatar
the problem is when u take photos at lower resolution and increase its resolution casues the photo to pixelize i.e the more u zoom into the photo the more it gets blurred or distorted.for resizing the potos u can use picasa or irfan view.
phatratt is offline
Old 10-05-2006, 09:11 PM   #8 (permalink)
Searching...
well my bro has E398 an dhe has installed one sft for full screen... so its possible for E398.. sooner or later it should be fo L6 also then... if you guys know any pls help THX..
amol48 is offline
Old 12-05-2006, 01:16 PM   #9 (permalink)
Hi phatratt, thanks for all your suggestions. I do understand about pixelization while zooming. You have not understood my problem. I mean when I put .jpg pictures on my mmc from my computer, most of these pics have resolutions higher than 640 x 480, thats when the problems comes in. The L7 does not open them. So do you mean i can reduce the resolutions of my pictures down to 640 x 480 by using picasa or irfan view, well if that is possible, then i will download these softwares, plz let me know. thanks once again.
lovemeall26
CHEERS,
LOVEMEALL26
Old 12-05-2006, 10:31 PM   #10 (permalink)
phatratt's Avatar
@lovemeall,yes u can reduce the resolution of the image using irfan view,its a freeware.
phatratt is offline
Old 15-05-2006, 07:26 PM   #11 (permalink)
prasad_den's Avatar
Can you post the name of the software...??
Old 20-05-2006, 06:07 PM   #12 (permalink)
Exclamation Re: Motorola L6 help !!
I 've got a Motorola L6 cellphone, can you please give the settings in detail for using Airtel GPRS, i tried with the customer Care, but they themself are unaware of settings for Motorola L6.
I also want to use the cellphone to connect to the Internet through Bluetooth via PC, are specific settings on PC are required in this regard?
I don't know much about these things, I'll be grateful if you help.
Regards,
Plusthought aka Mahesh
plusthought@gmail.com
plusthought is offline
Old 21-05-2006, 05:45 PM   #13 (permalink)
sidewinder's Avatar
whoa...................thats why i love symbian phones.. coz in case of softwares u name it u got it...........
sidewinder is offline
Old 21-05-2006, 05:52 PM   #14 (permalink)
deathvirus_me's Avatar
All the settings are same for all mobile phones ....
Just make sure ur pc support usb2.0 .. and get a cheap bluesoliel adapter .. that'd do ..
deathvirus_me is offline
Old 26-05-2006, 11:41 AM   #15 (permalink)
oh thanks a lot phatratt - that is what i wanted to know, i will download it and hope it works like the way you said it. thanks a million for all ur suggestions.
lovemeall26
CHEERS,
LOVEMEALL26
Old 26-05-2006, 04:19 PM   #16 (permalink)
montsa007's Avatar
dude u can press the screw button and select to play in fullscreen so u can enjoy(i tested it on moto c975)
montsa007 is offline
Old 30-05-2006, 01:15 PM   #17 (permalink)
Can u guys post here the link to the s/w that plays fullscreen in E398...
I once Had a dream!!! Now I have Motorola !!!
My E398 Specifications
Software: R373_G_0E.30.48R
Hardware:AAUG1627AH
Flex: MotoMaster V1.0
iTunes Songlimit 32000
Video Recording 1min 30 sec
MotoMaster is offline
Old 30-05-2006, 03:04 PM   #18 (permalink)
montsa007's Avatar
dude its the same procedure no need of any s/w press the screw and select play in fullscreen k?
Old 30-05-2006, 03:16 PM   #19 (permalink)
But theres no such option in E398....
Hardware:AAUG1627AH
Old 30-05-2006, 09:03 PM   #20 (permalink)
I've got anew Motorola L6.
The problem is that it doen't allow me to download/install any Java App. either from GPRS (thru mini Browser) or from Bluetooth.
It only allow me to upload JPEG,3GP,mp3,amr,midi files thru My Bluetooh device software.
Please Help
Also can you sugess any Application Loader software so that I can use my Data cable for uploading software to L6.
Thanx
MyL6 is offline
Old 21-02-2007, 10:09 PM   #21 (permalink)
Where is the Outbox?! i've looked in the help booklet but it doesn't say and i just can't seem to find it! Can someone pleaaaaaase tell me. Thanks x
dannilango is offline
Old 21-02-2007, 10:12 PM   #22 (permalink)
Google Bot
Pathik's Avatar
i suppose it shd be in the messaging menu...
Pathik is offline
Old 23-02-2007, 02:48 AM   #23 (permalink)
ok my problem may make me sound like a tool but im using p2k commander to trnsfer files to my phone but i have no clue which folders to put them in so when i do transfer them, my L6 does not read them any help would be good!
jamie281180 is offline
Old 15-11-2008, 07:37 PM   #24 (permalink)
hi. is it possible to view photos in fullscreen mode in l6i? please reoly
GaganDeep Singh is offline
