| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#6 (permalink) | |
Wire muncher!
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#8 (permalink) |
SE K700i can be use as webcam with app called-- K700WebCam
INFO-- With the program K700 Webcam it is possible to use your mobile as a Webcam. It takes a foto which is uploaded to your pc and transfered to your FTP Server after that. You can just let upload the foto or also a HTML file. This HTML file can be used to show the datetime of the foto or the refreshinterval. Check out this topic in the forum. Funktions: Webcam FTP Transfer Backup pictures on your PC Simple scriptlanguage Limitations: Thanks to SE there is no way to get the status of the keylock in the K700. So you have to check if the keylock is disabled before the first foto. You can't disable the cameratone with this program! It's only possible on free K700. It works only in fotomode no live stream! Options to Connect: Seriell Cable USB Cable Infrared (over Comport) Bluetooth (over Comport) Tested Mobiles: K700 K500 S700 T610 T630 Z600 link Snapshot It works @infra_red_dude---------- plz give your comment thanks to all |
#9 (permalink) |
Wire muncher!
dunno why but our previous posts disappeared when the database was migrated!
anyways, wot this software does is that it connects to ur photo via an actual or virtual serial port (bluetooth, usb etc)...clicks pics at certain intervals..instantly transfers to pc and deletes from the phone. u can't stream video... nevertheless a good find pinklip!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
