Old 11-04-2006, 11:18 AM   #1 (permalink)
Default PUK code?? Urgent
My Sim card is blocked.. It is asking for PUK code .. PLz help.. My Phone model is Nolia 6610i. Hutch subscriber..
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 11-04-2006, 11:59 AM   #2 (permalink)
desertwind's Avatar
Call ur hutch customer care. Only they will be able to answer you. You'll need ur sim card no (not mobile no), so keep it ready.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 11-04-2006, 01:38 PM   #3 (permalink)
contacted Hutch CC and got the PIN code as well as PUK code. Now is this PIN code and PUK code permanent ?? If so , how to change the PUK and PIN no..
Mobo- MSI PM8M-V
XFX FX5200 128 MB
medigit is offline
Old 11-04-2006, 03:26 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Afaik, u can change the PIN and PIN2 Codes from ur mobile sets!
In Nokia u can change these codes from Menu -> Settings -> Security Settings -> Access Codes
http://www.AskVG.com/
Vishal Gupta is offline
Old 11-04-2006, 03:32 PM   #5 (permalink)
Professional Layabout.
pickster's Avatar
The PIN code can be changed from within the mobile, but AFAIK, PUK code can't be changed.
pickster is offline
Old 11-04-2006, 09:04 PM   #6 (permalink)
puk sometimes comes with the box you buy the phone in.
kris147 is offline
Old 11-04-2006, 11:52 PM   #7 (permalink)
aku
Gonna make it BiG
aku's Avatar
Location: Familiar with Java... SORRY POINTER NOT ALLOWED!!!
noo way..@kris147.. datz IEMI ur takin abt
aku is offline
Old 17-04-2006, 08:12 PM   #8 (permalink)
no earlier puk code used to come with the sim card
amit_stg is offline
Old 17-04-2006, 10:18 PM   #9 (permalink)
moshel's Avatar
u dont need PUK code ever except when ur phone gets locked........the phone gets locked if u enter the Pin no. wrong 3 times. then it asks for the PUK code which if u put wrong 10 times, ur sim will get blocked permanantly, then u will have to buy a new sim, u will get the same phone number but u will lose all the data on the sim.....
BTW PUK code depends on ur sim, even if u get ur sim replaced, just casually , the PUK code will change. each sim has a puk code, which itself never changes. so if ur phone gets locked again u can punch in the same puk no. once again to unlock it.
moshel is offline
