Old 06-04-2006, 08:41 AM   #1 (permalink)
vwad's Avatar
Location: Why ? Are you coming for dinner ? Pls. Don't.
Default How to surf websites NOT WAP enabled on mobile phone ?
Hi Team,
I want to surf icicidirect.com which uses asp scripting I think and 128 BIT and SSL security features.
Will I be able to login and trade online on my mobile phone ?
Which non-pdf high-end phone models will support this feature ?
(Nokia preffered )
Thanks in advance
Regards,
vwad
An Old Lady Died In Her Childhood.
vwad is offline
Old 06-04-2006, 10:48 AM   #2 (permalink)
I have Nokia 6630 and it supports html browsing with ssl.
alanpaladka is offline
Old 06-04-2006, 10:49 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yeah, almost all new phones support SSL and HTML browsing. Plus if u want to visit some high-sized sites, use google mobile
Harsh J
www.harshj.com
QwertyManiac is offline
Old 12-05-2006, 09:53 PM   #4 (permalink)
vwad's Avatar
Default Re: How to surf websites NOT WAP enabled on mobile phone ?
can asp scripted sites like icicidirect.com be surfed on it ?
vwad is offline
Old 15-05-2006, 11:25 PM   #5 (permalink)
String Phreak
mediator's Avatar
U shud specify ur phone model......If it supports java,jar apps then u may install "opera mini"...downloadable from opera site. Its awesome + its browsing speed is superb, much better than the browser supplied with the phone!
mediator is offline
Old 16-05-2006, 04:06 AM   #6 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Where you living? Just go for opera mini - 5x faster, and it compresses dat a to 1/5th saving precious money.
chesss is offline
Old 21-05-2006, 04:51 PM   #7 (permalink)
vwad's Avatar
OK I am sorry
I have I-mate SP3i Smartphone.
Will I be able to surf the site icicidirect.com on it now ?
vwad is offline
