| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
does it come with usb cable and necessary softs to connect to pc without any problem,,,,,,does it come with ear phones,,,,,can i play videos on it and in which format,,,,,and finally should i buy it ????? |
#3 (permalink) |
Professional Layabout.
Sony Ericsson K750i is a good phone.
It comes with earphones, USB data-cable, drivers, etc. You will be able to run softwares and games but those which are only java based. No .sis files. You can play video files on it but it was not evident from the site which format. BTW, don't make two different posts. You can edit your previous one. |
#4 (permalink) |
The k750i support .3gp & .mp4 video formats
It comes with the USB cable for PC connect...and an excellent pair of headphones....I believe SE is also providing the external flash as a standard accessory these days.....so its a good time to get the K750..... |
#5 (permalink) |
Yeah-SE does provide a 64 Mb card as an accesory.
Also, i would recommend checking out the w800i too while getting the k750-its got more memory-512 mb as default(u can also buy a card for the k750 to increase the mem) and the earphones rock-its a wlakman fone after all not trying to change your mind..just a humble suggestion...
If u think u r right...u r a bad thinker! |
#8 (permalink) |
Yeah..but the Software is different too...
And i dont think the sound quality is the same..w800i has very good speakers... Neways..its not as simple as the equation you have writen..altho it would have been gr8 were it been true!
#9 (permalink) |
Wire muncher!
well actually yes! you can just flash a w800i firmware onto a k750i. i'd posted about it elsewhere in this forum. other than that its actually the same base!
w800i's got a 3.5mm phone jack for headset...
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
