Old 30-03-2006, 09:25 PM   #1 (permalink)
Default repl
I have Ngage Qd Brand mobile. after installing laud wave application on my ngage, my ngage give alarm in every 5 minutes help me.
procedure of installing wav loud:
1. the installer have 27 wav files and have 2 txt files names tclock.txt
2. copy that all to on mobile using fxplorer c:\nokia\sound\digital\--- dir name which given in setup method
3. after doing this my mobile beeps alarm in every 5 second and telling now 10.15 am and as long as.
help.
sorry for english
jojoji_jojo is offline
Old 30-03-2006, 10:03 PM   #2 (permalink)
Professional Layabout.
pickster's Avatar
Hey, you are the same guy to whom I said "Can't understand your problem."
So, why have you created another topic? You should have posted in that topic only...
pickster is offline
Old 30-03-2006, 10:16 PM   #3 (permalink)
pickster's Avatar
If it is a virus then you can install Symantec Mobile Security. More info HERE.
If not, then you can also format you memory card [not sure whether this will help, probably should].
pickster is offline
Old 31-03-2006, 11:12 PM   #4 (permalink)
moshel's Avatar
the best thing wud be do format ur phone by going to a nokia care. or u cud try opening that txt file in ur comp and see what it contains. or just copy the file in ur comp then delete the file frm there and then try. or u cud try uninstalling the software. by going to the applications menu
moshel is offline
