Old 30-03-2006, 11:58 AM   #1 (permalink)
Default alarm beep in 5 minutes interval, virus
I am facing new problem on my ngageQd, once i search a forum which tells for loud wav on my cell and the procedure of this software copy some wav files on c:\nokia\sound\digital\newfolder and which names given by owner manufacture and 2 txt files naming tclock.txt and other, after copy and save the files, my cellphone give a alarm beep and see time is now 10.10 am give on 5 minutes interval ples help how to remove this kind of trick ,
thanks
jojoji_jojo is offline
Old 30-03-2006, 12:20 PM   #2 (permalink)
Professional Layabout.
pickster's Avatar
Can't understand your problem....
Write with better english...
pickster is offline
Old 30-03-2006, 11:04 PM   #3 (permalink)
moshel's Avatar
yes buddy its very difficult to understand...btw did u mean to say that u tried to change the alarm sound?
and its ringing every 5 mins, just check if alarm is on in ur mobile, cos when alarm rings u need to turn it off. if u press snooze, it will ring again in 5 minutes
moshel is offline
Old 30-03-2006, 11:56 PM   #4 (permalink)
pickster's Avatar
see this dude's other post titled reply
he posted again there
pickster is offline
