Old 29-03-2006, 10:35 AM   #1 (permalink)
gdatuk's Avatar
Default Audio adapters
IS Nokia HS-6 Display Headset compatible with Nokia N70?
Is Nokia Audio Adapter AD-15 [AD15] or Nokia Audio Adapter AD-46 available in india? anyone used it? how is it??
Where can i get any of these in chennai
Twitter @cgiridhar
Moto Milestone | Rooted | Froyo | CM 6.1.0
AMD Phenom2 720 x3 BE | Gigabyte MA78G | WD 500Gb+Seagate 1TB ext | PSU Corsair vx450 | Corsair 2x2gb RAM | Bose Companion 5
gdatuk is offline
Old 30-03-2006, 03:31 AM   #2 (permalink)
According to Nokia's European website, the HS-6 is compatible with the following phones:
7370, 6270, 6280, 6230i, 6131, 6101, 6103
Link
I couldn't find the Audio Apaters on the Nokia India site so I guess you should try and contact Nokia India or a Nokia dealer in Chennai to see if they are available.
Nemesis is offline
Old 30-03-2006, 07:35 AM   #3 (permalink)
mobilegeek's Avatar
I asked that before from many priority dealers .. none of them had a clue.
I wanted to use some other headphones, .. since the one with 6630 doesnt fit in ear properly.
But what to say .. Nokia doesnot launch eveything in India.
Also you dont find 1GB Nokia Card at dealers, .. but a grey market stuff.
mobilegeek is offline
Old 30-03-2006, 08:12 AM   #4 (permalink)
gdatuk's Avatar
ok ill try the richie st this weekend and let u know....
Twitter @cgiridhar
gdatuk is offline
