Old 27-03-2006, 06:33 PM   #1 (permalink)
Mobile Freak
reddick's Avatar
Default Blank Screen - HELP!!!
I have Nokia 6230.My phone fell down n after that it's screen turns all BLANK...As i can make n recieve call but anyone tell me why is it so I open d back cover but everything seems to b fine..Please tell me how to fix it...THX FOR UR PATIENCE!!!
Hope 4 d best n Do d right :)
reddick is offline
Old 27-03-2006, 09:50 PM   #2 (permalink)
18 Till I Die............
Did you try applying pressure on both sides of the screen to check if you can see anything on the screen?
If you can see anything on the screen then I think it can be repaired.
http://www.bash.org/?258908
mehulved is offline
Old 28-03-2006, 12:04 AM   #3 (permalink)
Show it to a mobile repairer..u seriously didnt expect this forum to help you wid a hardware prob like dis..did u??
If u think u r right...u r a bad thinker!
Jatin_T is offline
Old 28-03-2006, 06:26 AM   #4 (permalink)
Mobile Freak
reddick's Avatar
Today whn i charge it,suddenly d screen blinks n it starts working of it's own But after 10-15 mins it again becomes BLANK Wht d hell is this issue
reddick is offline
Old 28-03-2006, 12:39 PM   #5 (permalink)
The screen has got some circuitry loose. My cell has the same problem but I can see on the screen most of the times. Othertimes when the screen goes blank a bit of pressure on the screen helps in restoring it.
mehulved is offline
Old 28-03-2006, 02:13 PM   #6 (permalink)
aadipa's Avatar
You may have to fix connections to screen which may be loose, please take your phone to phone repair shop.
These parts are not self-repairable.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 28-03-2006, 09:20 PM   #7 (permalink)
moshel's Avatar
aadipa's right.....and also u must not try to repair it urself if u dont have proper knowledge, if the LCD goes out by chance u will have a big "financial" loss
moshel is offline
Old 28-03-2006, 11:01 PM   #8 (permalink)
Mobile Freak
reddick's Avatar
So wht do u suggest...i shouls rather visit NOKIA showroom or 3rd party repair shop...Wht's d difference between these two fields?
reddick is offline
Old 28-03-2006, 11:19 PM   #9 (permalink)
Nokia showrooms for sure. I had my old cell messed up by a 3rd party repairer and had to throw it away. Nokia shop is safer.
mehulved is offline
Old 28-03-2006, 11:26 PM   #10 (permalink)
moshel's Avatar
how cud u even ask such a question reddick. Nokia care is the best even if ur phone is in warranty or not. its controlled by the company. also if ur phone is in warranty and u take it to a third party repairer, the warranty m8 get void.
and if u go to just any repairer he can looooot u bigtime. so nokia shops is the best/only place to go.
and u need to go to NOKIA CARE not to NOKIA PRIORITY DEALER
moshel is offline
Old 29-03-2006, 06:34 PM   #11 (permalink)
Mobile Freak
reddick's Avatar
That's O.K for ur replies.But tell me wht's d difference between 'NOKIA CARE' n 'NOKIA PRIORITY DEALER'?
The DEALER can too repair my phone...An NOKIA showroom is placed near d market along side my house,but i don't know whether they r DEALER or NOKIA CARE?
reddick is offline
Old 30-03-2006, 01:17 PM   #12 (permalink)
Nokia Priority Dealers are those who retail Nokia Cellphones...i.e they sell them...Nokia Care is the place you take your phone to get repaired if something goes wrong with the phone...You will NOT be violating the terms of warranty if you take your cellphone to repair to Nokia Care...If that showroom along side your house is a Nokia Priority Dealer ask them where the nearest Nokia Care is..they will be able to help you...Hope this helps...
blue_earth is offline
