Old 24-03-2006, 06:37 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
sidewinder's Avatar
Default How to uninstall real player in Nokia 3230???
gUYS...MY bro has a nokia 3230 that comes with real player preloaded.And now he wants to install real player advanced.But the problem is how to uninstall built in real player first?
Cant see its entry in application manager.
If I install real player advanced over it everything is getting corrupted nd had to do a format.
Any idea?
TIA
sidewinder is offline
Old 24-03-2006, 01:50 PM   #2 (permalink)
Before doing this back up your phone memory.
Use a file explorer and not applications manager and navigate to systems\app\ .
You will find the realplayer folder delete it.
Then try installing real advanced.
REDspot is offline
Old 24-03-2006, 02:30 PM   #3 (permalink)
sidewinder's Avatar
already tried that using fileman.seleQ nd flexplorer but to my amaze there is no folder named real or somthing like that inside apps directory.
Any idea?????
Old 24-03-2006, 02:45 PM   #4 (permalink)
I think its integrated with the rom
Try the z drive .
If its present in there then you cant delete it. Go for firmware upgrade instead
REDspot is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/mobiles-tablets/25931-how-uninstall-real-player-nokia-3230-a.html
How to uninstall real player in Nokia 3230 Mobile Monsters Question This thread Refback 22-07-2010 04:26 AM
