Originally Posted by evil_maverick
well..... u may try using *#7370#!! but plz proceed with extreme caution!!
this command resets the fone and then restores everything to its default setting!! and obviously wipes everythin frm the fone mem!! i strongly advise u to not use this command .... u better go to a nokia care center and let them handle it 4 u!!
chao!!
well its will restore factory settings....of u want to format ur ph..
use "*" +"3" + "call button(green) ,switch off and switch on...a flashing screen comes...like formating the phone(in some %)..but remember do keeo charge the ph before u do this....
i hadnt tried this in n6630...as bought tht some days back..but works well in n3230 and n6600...old ph's i used...
