Samsung Tips & Tricks + Codes
----====----||HELP MENU||----====----
First of all u shud key in the code
*#9998*HELP# to know wat all codes r supported by ur cellfone.(HELP=='4357').
----====----||SECRET CODES <1>||----====----
1. *#06# IMEI code
2. *#9998*5282# Java menu (GRPS/CSD settings for JAVA server)
3. *#9999#0# Monitor Mode
4. *#9999# or *#9998*9999# Software Version
5. *#8888# or *#9998*8888# Hardware Version
6. *#9998*746# or *#9998*0746# or *#0746# Sim Infos
7. *#9998*523# or *#9998*0523# or *#0523# Display Contrast
8. *#9998*842# or *#9998*0842# or *#0842# Vibration On (until you push OK)
9. *#9998*289# or *#9998*0289# or *#0289# Buzzer On (until you push OK)
10. *#9998*288# or *#9998*0288# or *#0288# Battery & Field Infos
11. *#9998*377# or *#9998*0377# Error log
12. *#9998*778# or *#9998*0778# or *#0778# Sim Service table
13. *#9998*782# show date and alarm clock
14. *#8999*638# show network information
15. *#9998*5646# change operator logo at startup
16. *#9998*76# production number
17. *#9998*968# view melody for alarm
18. *#9998*585# Non-Volatile Memory (NVM)
19. *#3243948# Digital Audio Interference Off
20. *#32436837# Digital Audio Interference On
----====----||TRICK <1>||----====----
When any problem occours in ur fone due 2 corrupted/incompatible media or Java Midlet appz, u may try out the followings:--
1. *2767*JAVA# Java Reset and (Deletes all Java Midlets)
2. *2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
3. *2767*WAP# Wap Reset
4. *2767*CUST# Reset Custom EEPR0M
5. *2767*FULL# Reset Full EEPR0M (!! C A U T I O N !!)
(Tested in C-Series)
----====----||V- SERIEZ CODES||----====----
1. *#9324# Netmon (press the hangup key to exit)
2. *#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
3. *#9998*Help# Help screen/ List of codes
4. *#9998*LOGO# Change operator Logo
5. *#9998*RTC# RTC Display
6. *#9998*Bat# Battery Status
7. *#9998*Buz# Turns Buzzer ON
8. *#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
9. *#9998*Help# Help screen/ List of codes
10. *#9998*LOGO# Change operator Logo
11. *#9998*RTC# RTC Display
12. *#9998*Bat# Battery Status
13. *#9998*Buz# Turns Buzzer ON
14. *#9998*Vib# Turns Vibrator ON
15. *#9998*LCD# LCD Contrast
16. *#9998*9999# Softwre Version
17. *#9998*8888# Hardware Version
18. *#9998*377# NVM Error Log (?????)
19. *#9998*NET# SIM Network ID
20. *#9998*778# SIM Serv. Table
21. *#9998*SIM# SIM Info
22. *#9998*PN# Production No.
23. *#9998*968# Reminder Tune
24. *#9998*NVM# Displays Non-Volitile Memory Status
25. *#9999*C# ???????????????????
26. *#06# Displays phones I**I No.
27. *2767*MEDIA# Resets the medis on the phone (deletes all downloaded pics/tones)
28. 2767*FULL# Resets the EEPRON *DANGEROUS*
29. *2767*CUST# Resets the Custom EEPRON
30. *2767*JAVA# Resets JAV downloads (deletes all downloaded midlits)
31. *2767*STACKRESET# Resets Stack
32. *2767*225RESET# ????????????????? * Dangerous *
33. *2767*WAP# Resets WAP Setting & Deletes Favorites
v200 Unlock Code -- *2767*7822573738#
----====----||X - SERIEZ CODES||----====----
1. #*0000#
2. #*1200# - AFC DAC Val
3. #*1300# - IMEI
4. #*1400# - IMSI
5. #*2252# - Current CAL
6. #*2256# - Calibr.-Info
7. #*2286# - Databattery
8. #*2337# - ( ) Permanent Registration - Not Yet Implemented
9. #*2400# - ( ) Command #*2400 Executed
10. #*2474# - For CMD Set - DEBUGBATTERY in cihard.opt
11. #*2527# - GPRS Switching Set to class {4/8/9/10}
12. #*2558# - Time ON
13. #*2677# - AMR State: {None / Full Rate}
14. #*2679# - Copycat Feature: {ACTIVATED/DEACTIVATED}
15. #*2787# - CRTP {ON/OFF}
16. #*2834# - Audio path Mobile Normal
17. #*2836# - AVDDSS Management: {DEACTIVATED/ACTIVATED}
18. #*3230# - Trace Enable DCD disable
19. #*3231# - Trace disable DCD Enable
20. #*3232# - Current Mode {Trace enabled/DCD enabled}
21. #*3270# - DCS Support: {DEACTIVATED/ACTIVATED}
22. #*3282# - Data: {DEACTIVATED/ACTIVATED}
23. #*3353# - General Defence Code Erased
24. #*3476# - EGSM: {DEACTIVATED/ACTIVATED}
25. #*3676# - Flash Volume Formated
26. #*3737# - Some Codes
27. #*3825# - ( ) Command #*3825 Executed
28. #*3877# - Dump of SPY Trace
29. #*3940# - External looptest 9600 bps not available in SYSOL2
30. #*3940# - External looptest 115200 bps not available in SYSOL2
31. #*4263# - Handsfree Mode: ACTIVATED
32. #*4674# - IMSI| MCC:2 5 0 | MNC 9 2 | 10 11 91 83 50
33. #*4700# - Half Rate: {ACTIVATED/DEACTIVATED}
34. #*4760# - GSM: {ACTIVATED/DEACTIVATED}
35. #*5187# - L1C2G trace: {ACTIVATED/DEACTIVATED}
36. #*53696# - [Java dnload] WAPSAR mode
37. #*536961# - WAPSAR enable HTTP disable
38. #*536962# - HTTP enable WAPSAR disable
39. #*536963# - SERIAL enable Others disable
40. #*5400# - ( ) Command #*5400 Executed
41. #*566335# - [WAP model ID]
42. #*5663351# - [Phone Model] SAMSUNG SGH-X100
43. #*5663352# - [Java Model] SEC-SGHS300/1.0
44. #*5737425# - Java Serial
45. #*577699# - APN
46. #*5800# - ( ) Command #*5800 Executed
47. #*6100# - ( ) Command #*6100 Executed
48. #*6420# - Mic off
49. #*6421# - Mic on
50. #*6422# - Mic dep RXdata
51. #*6428# - Mic measurement
52. #*6837# - Official Software Version
53. #*7222# - Operation Typ: Class C GSM
54. #*7224# - ERROR
55. #*7252# - Operation Typ: Class B GPRS
56. #*7271# - Multi slot: Class 1 GPRS
57. #*7274# - Multi slot: Class 4 GPRS
58. #*7284# - Class B
59. #*7287# - GPRS Attached
60. #*7288# - GPRS Detached
61. #*7326# - Accessory: Vibrator
62. #*7337# - Some kind of Reset Settings
63. #*7352# - Some Kind of Debug Info
64. #*7462# - SIM phase
65. #*7524# - KCGPRS
66. #*7562# - LOCI GPRS
67. #*7632# - Sleep mode
68. #*7638# - RLC always open ended TBF: {ACTIVATED/DEACTIVATED}
69. #*7666# - SrCell Data
70. #*7673# - Sleep mode
71. #*7676# - Command #*7676 Executed
72. #*7683# - Sleep variable
73. #*7693# - Sleep deact
74. #*7728# - RSAV done->reset
75. #*7763# - SMS bearer CS {ACTIVATED/DEACTIVATED}
76. #*7828# - Midl Rl51
77. #*7957# - Command #*7957 Executed
78. #*7983# - Voltage/Freq {DEACTIVATED/ACTIVATED}
79. #*7986# - Voltage {DEACTIVATED/ACTIVATED}
80. #*8462# - Sleep time since SwitchOff
81. #*8465# - Time in L1
82. #*8466# - Old Time
83. #*9278# - Command #*9278 Executed
84. #*9795# - wtls key: reset
85. #7263867# - RAM Dump {On/Off}
86. #7465625*228# - Activa lock deactivated
87. #7465625*27*
88. #7465625*2827# - Auto CP lock deactivated
89. #7465625*28638# - Auto Network lock deactivated
90. #7465625*28746# - Auto SIM lock deactivated
91. #7465625*2877# - Auto SP lock deactivated
92. #7465625*28782# - Auto subset lock deactivated
93. *#06# – IMEI
94. *#2255# - Call List
95. *#4777*8665# – GPRS
96. *#7465625# – Interrogate ( )
97. *#8377466# – Software && Hardware Versions
98. *#8888# – Hardware Version
99. *#8999*324# - ( ) Some Strange Numbers
100. *#8999*3825523# - ( )
101. *#8999*523# - Main LCD Brightness
102. *#8999*636# - ( ) Another Strange Numbers
103. *#8999*8376363# - . HW, SW, + Some Code And Data
104. *#8999*8378# - . , , , HW SW
105. *#9999# – Software Version
106. *2767*xx927 - WAP . xx - . , xx=44: *2767*44WAP# xx=31: *2767*31WAP#
107. *2767*xx667 - MMS.
108. *2767*2877368#
109. *2767*2878# – EEPROM ( , )
*2767*31667#
*2767*31927#
*2767*33667#
*2767*33927#
*2767*34667#
*2767*34927#
*2767*351667#
*2767*351927#
*2767*3700#
*2767*380667#
*2767*380927#
110. *2767*3855# - l EEPROM ( SP- !! ) IMEI 447967-89-400044-0, IMEI ( )
*2767*39667#
*2767*39927#
*2767*420667#
*2767*420927#
*2767*43667#
*2767*43927#
*2767*44667#
*2767*44927#
*2767*46667#
*2767*46927#
*2767*49667#
*2767*49927#
*2767*66335#
111. *2767*688# ( ) [Unlocking Code]
*2767*7100#
*2767*7300#
112. *2767*73738927# = *2767*RESETWAP#
*2767*7650#
*2767*7667#
*2767*7927#
*2767*8200#
*2767*927#
*335#
113. *663867# - mm file dumped
*7465625# -
114. *7465625*228# - Activa lock personalized
*7465625*27*
115. *7465625*2827# - Auto CP lock activated
116. *7465625*28638# - Auto Network lock activated
117. *7465625*28746# - Auto SIM lock activated
118. *7465625*2877# - Auto SP lock activated
119. *7465625*28782# - Auto subset lock activated
*7465625*638*
*7465625*746
*7465625*746*
*7465625*77*
*7465625*782*
----====----||TRICK <SOUND++>||----====----
Enter the following code:
*#8999*8378#
(menu appears)
"H/W test"
"Audio Settings"
"Melody Gain"
There will you see a number. There are five (5) 'Melody Levels' of it.
Press Save button to move 2 a higher level.
the higher the level, the louder the melody sound!
Even more louder then the max. ringing volume.
the level wise numbers are:
Melody Level 1: 13
Melody Level 2: 17
Melody Level 3: 18
Melody Level 4: 25
Melody Level 5: 31
Worked in A-Series
----====----||T-SERIEZ CODES||----====----
1. *#06# -> Show IMEI
2. *#9999# -> Show Software Version
3. *#0001# -> Show Serial Parameters
4. *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also
5. hange IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it)
6. *2767*2878# -> Custom EEEPROM Reset
7. *#8999*228# -> Battery status (capacity, voltage, temperature)
8. *#8999*246# -> Program status
9. *#8999*289# -> Change Alarm Buzzer Frequency
10. *#8999*324# -> Debug screens
11. *#8999*364# -> Watchdog
12. *#8999*377# -> EEPROM Error Stack
13. *#8999*427# -> Trace Watchdog
14. *#8999*523# -> Change LCD contrast
15. *#8999*544# -> Jig detect
16. *#8999*636# -> Memory status
17. *#8999*746# -> SIM File Size
18. *#8999*778# -> SIM Service Table
19. *#8999*785# -> RTK (Run Time Kernel) errors
20. *#8999*786# -> Run, Last UP, Last DOWN
21. *#8999*837# -> Software Version
22. *#8999*842# -> Test Vibrator
23. *#8999*862# -> Vocoder Reg
24. *#8999*872# -> Diag
25. *#8999*947# -> Reset On Fatal Error
26. *#8999*999# -> Last/Chk
27. *#8999*9266# -> Yann debug screen (=Debug Screens?)
28. *#8999*9999# -> Software version
29. SAMSUNG V200 SECRET CODES v200 Unlock Code-> *2767*7822573738#
30. *#9324# Netmon (press the hangup key to exit)
31. *#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
32. *#9998*Help# Help screen/ List of codes
33. *#9998*LOGO# Change operator Logo
34. *#9998*RTC# RTC Display
35. *#9998*Bat# Battery Status
36. *#9998*Buz# Turns Buzzer ON
37. *#9998*JAVA# Edit GPRS/ CSD settings (S100 Only)
38. *#9998*Help# Help screen/ List of codes
39. *#9998*LOGO# Change operator Logo
40. *#9998*RTC# RTC Display
41. *#9998*Bat# Battery Status
42. *#9998*Buz# Turns Buzzer ON
43. *#9998*Vib# Turns Vibrator ON
44. *#9998*LCD# LCD Contrast
45. *#9998*9999# Softwre Version
46. *#9998*8888# Hardware Version
47. *#9998*377# NVM Error Log (?????)
48. *#9998*NET# SIM Network ID
49. *#9998*778# SIM Serv. Table
50. *#9998*SIM# SIM Info
51. *#9998*PN# Production No.
52. *#9998*968# Reminder Tune
53. *#9998*NVM# Displays Non-Volitile Memory Status
54. *#9999*C# ???????????????????
55. *#06# Displays phones I**I No.
56. *#9998*2576# Forces SIM Error
57. *#9998*DEAD# Forces Phone Crash
(Final Word... well some of these tricks/codes r really risky 2 play with... porceed with ur own risk
(Anything missed out by me???
... Inform me!)
Well Datz all for Nw!!!
