Old 22-02-2006, 08:58 AM   #1 (permalink)
Default nokia 6270
Hi guys,
my friend bought a n6270 and i think it is a s40 phone ..could anyone suggest any application to view .avi movies on phone and a file manager .. Since i cant find any java apps
khin007 is offline
Old 28-03-2006, 09:35 PM   #2 (permalink)
My friend also bought it but we r unable to find suitable applications for it.
Can anyone help
Techmastro is offline
Old 28-03-2006, 10:09 PM   #3 (permalink)
Professional Layabout.
pickster's Avatar
There are very less applications available for java in the multimedia segment. It will play only the files supported by the phone. You can try www.gatjar.com.
Another method is to convert the .avi files into files supported by Nokia 6270 which are : 3GPP, H.263 video, MPEG-4, and AMR
pickster is offline
