Old 17-02-2006, 07:38 PM   #1 (permalink)
maharajadhiraj's Avatar
Default nokia 6630 or nokia 6600
hey guys i m thinking of buying either a nokia 6600 or 6630, which one do u recommend?
cud u pls list the features of them both nd give ur views?
Or should i try k700i instead of the 2 models listed above?
maharajadhiraj is offline
Old 18-02-2006, 12:50 AM   #2 (permalink)
aadipa's Avatar
In all handsets you given, N6630 is best value for money, only that it lacks FM which is in SE K700i.
N6600 is strictly no-no.
SE K700i is also good no expandable memory (only 38 MB).
Other options are W550i for its superb sound, but again no expandable memory (only 230 MB)
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 18-02-2006, 01:12 AM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
yeah, just strike out 6600 from the list.
k700i:
fm, 41mb memory (non-expandable), quite good clicks in dark, flash for the camera, cheaper than n6630, bt, ir, excellant stereo headphones bundled, not symbian os enabled.
6630:
quite good camera, no fm, expandable memory (rs-mmc), no flash, symbian os, 3g, bluetooth, no ir, good customisation options.
decide yourself!
infra_red_dude is online now
Old 18-02-2006, 11:11 AM   #4 (permalink)
I dont wanna go for k700i b'cos it has a limited non-expandable memory of 41MB.
Now its either 6630 or 6600. Does 6600 hv FM?
Do u suggest any other phone with the features of 6600. my budget is 12k
Old 18-02-2006, 11:27 AM   #5 (permalink)
Wire muncher!
nope 6600 doesn't haf fm. just strike it off ur list dude! its just tooooo old! 6630 doesn't haf fm either! hmmm..for 12k, i'd suggest u haf a look at 6230i too.
Old 18-02-2006, 01:29 PM   #6 (permalink)
It isn't even a competition. The 6600 is simply outdated when compared to the 6630.
iBrood is offline
Old 19-02-2006, 09:47 PM   #7 (permalink)
Hey guys, i don't want in-built radio. So shud i FINALLY buy 6630?
Also, pls list the features of 6230i.
Thnx a lot.
Old 22-02-2006, 03:42 PM   #8 (permalink)
I think you buy a 6630
<hi this is Symbian>
mobile_freak_2020 is offline
Old 25-02-2006, 01:22 AM   #9 (permalink)
you should buy the same price to 6630 i.e nokia 3230 which has fm radio as well and expandable memory as wel adn its symbian !
dead is offline
