Old 07-02-2006, 08:31 AM   #1 (permalink)
gdatuk's Avatar
Default 3230 formatting
i have a 3230. and it is corrupted now..i need to format the phone..
i trid 7780 code..but it just restores the factory defaults..nothing much...
can anyone tell me anyother ways to format...
Originally Posted by i read this from this forum..but not working
heard the code *#7780# works too, pretty much the same i tink.
for 6600 users, to format the fone, theres an alternative way. Press and hold <3>, <*>, and the buttons, then power on fone, keep holding on the 3 buttons, till u come to a format screen. tis method ONLY works on 6600, and need not enter the sec code. BUT sec code wun be reset to default 12345.
gdatuk is offline
Old 07-02-2006, 08:43 PM   #2 (permalink)
champ_rock
champ_rock's Avatar
my recommendation would be to take it to a nokia priority dealer............ they install the new firmware..........
Registered Linux user number 400618
champ_rock is offline
Old 18-02-2006, 12:20 PM   #3 (permalink)
Well,i tried the three button combo on my phone,and it worked.Let me tell u again:
* + Call + 3 + Power
Try it again.It'll work.
sujit.pawar is offline
Old 18-02-2006, 10:58 PM   #4 (permalink)
readermaniax's Avatar
IM NOT SURE ABOUT THIS >>>>
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
5. After a few minutes when the Full phone formatting completed, your 3230 will back to original system and factory settting.
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
