Old 03-02-2006, 11:28 AM   #1 (permalink)
D PrankMaster
prankie's Avatar
Default memory stick duo in card reader???
i recently bought a 14 in 1 card reader for my w800i..
please help me to find out that out of 4 slots where will the MS Duo go..
i've tried inserting it in every slot.
will i need an adaptor???
prankie is offline
Old 03-02-2006, 08:29 PM   #2 (permalink)
you need a adapter which is supplied with the box... but i think it wont work coz i ve tried it many times to use mem card reader for ms duo with adapter i ve even tried it with three diffrent adapter and four mem card reader it wont read in mem card reader.. i think the data cable supplied with phone will do the trick.... u can still load songs witout using mem card reader..
Rasper is offline
Old 08-02-2006, 05:44 PM   #3 (permalink)
.:My Name is Bond:.
montsa007's Avatar
babes did u install the software coz ms requires the software
I do web designing for high profile clients - PM me to get yours done~
montsa007 is offline
Old 08-02-2006, 08:29 PM   #4 (permalink)
Location: don't drink and drive you might spill your beer
well, I guess there'll be two very big slots( for X Flash, Smart Media etc.). Ofcourse, Duo won't go into that. Out of the two left one is for the Noia MMC Card or MS card. The other is for Duo.
The key point is that you have to insert the duo with the reverse inside i.e. if the card reader is placed with its name on the top, then insert the duo such that the golden conductors are visible to you and the duo is on reverse. Got it? I hope so
pakkasir is offline
