Old 31-01-2006, 04:10 PM   #1 (permalink)
Default PC TO MOBILE DATA TRANSFER!
Hey guys i have se k700i and i have great camera pics of my study trip to ganpatipule.I donot know how to transfer those pics from mobile to pc.I have windows xp sp2.How to use infrared?Please help me!
Th nks in advance,
mandar
EVERYBODY WANTS TO GO TO HEAVEN BUT NOBODY WANTS TO DIE
mandar5 is offline
Old 31-01-2006, 10:24 PM   #2 (permalink)
18 Till I Die............
SInce you haven't mentioned I will ask you first if you have a infrared adapter for your PC?
You need to connect it to the USB of your PC and install its drivers. Then you can easily connect PC to your cell using its software.
If you can buy it, bluetooth will be a better option. It isn't that much expensive than infrared adapter but gives you much faster speeds and uninterrupted connectivity.
You can use Float's Mobile Agent instead of infrared/bluetooth's software.
http://www.bash.org/?258908
mehulved is offline
Old 31-01-2006, 10:31 PM   #3 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
yup,Float's Mobile Agent is the best for SE phones and will fulfill all ur needs.
n00b forever...
~Phenom~ is offline
Old 01-02-2006, 08:54 PM   #4 (permalink)
Default thanks
Can u simplify further plz?
mandar5 is offline
Old 01-02-2006, 10:12 PM   #5 (permalink)
First things first. have you connected and checked that the infrared adapter bought by you is working or no?
mehulved is offline
Old 01-02-2006, 10:13 PM   #6 (permalink)
rajesh's Avatar
To transfer files b/w PC and mobile You need a connection b/w the 2. There r 3 ways
1. USB data cable
2. InfraRed
3. Bluetooth
If u have a USB data cable then u can use connect the mobile to the PC thro' ur USB port.
Otherwise you can buy a bluetooth dongle and using it you can transfer data b/w the 2.
For any of the options you need the corresponding Drivers.
Hope this is helpful
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 04-02-2006, 04:11 PM   #7 (permalink)
Default thanks
thanks yaar rajesh,but i have heard that camera pics when transfered to pc remain the sane size ie just 2x3 inch ,is it true?
mandar5 is offline
Old 04-02-2006, 11:36 PM   #8 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: thanks
the pics will be of the same resolution they were clicked as. the size u see on ur computer display will vary according to the display size (ie 15,17,19 inch etc.) and the resolution at which it displays content. for e.g if ur display is set at 640x480 pix, a pic clicked at 640x480pix will be full screen and the one clicked at 1280x960 will go outta screen. if ur display is set at 1280x960pix a pic clicked at that resolution will be full screen while a pic clicked at 640x480pix will be smaller than the full screen view. the resolution and quality of the pic never changes. hope that clears the confusion.
infra_red_dude is offline
Old 05-02-2006, 03:43 PM   #9 (permalink)
Default thanks
What is the rate of bluetooth dongle ?Is usb cable cheaper than it?
mandar5 is offline
Old 05-02-2006, 05:29 PM   #10 (permalink)
USB cable costs more than bluetooth. Dunno the exact prices but bluetooth will come for around Rs. 400 and its range will be 10m to 100m depending on the brand you buy
mehulved is offline
Old 06-02-2006, 11:22 AM   #11 (permalink)
data cable is the first preference,as it is much much faster.....
Second is Bluetooth....
And then Infrared (it is vry slow)
get_biks is offline
Old 06-02-2006, 09:47 PM   #12 (permalink)
Wire muncher!
there is almost no difference in speed in data cable and bluetooth. this is coz both the usb bluetooth and the usb cable use a virtual com port for communication and the speed of which is limited to 115kbps. the only advantage wid bluetooth is that u haf the freedom to roam around the room and can also do a variety of tasks...the advantage wid a data cable is that the phone gets charged as it is used.
