Old 31-01-2006, 01:50 AM   #1 (permalink)
Default Nokia 3595
Is it possible to use Nokia 3595 in India?
If yes, then how?
subhranath is offline
Old 31-01-2006, 06:34 AM   #2 (permalink)
No ..
Since it is made for 850/1800 network in Same US states
whereas in India we have 900/1800 network only
>Do you have Nokia 3595?
mobilegeek is offline
Old 01-02-2006, 01:33 AM   #3 (permalink)
Ok...thanks for the explanation.
(Why would I ask the question if I don't have it)
Old 02-02-2006, 08:32 AM   #4 (permalink)
Just that .. you were looking for E398 or 6230 .. thats it
Old 03-02-2006, 12:33 AM   #5 (permalink)
Yes....you are right.....I was indeed looking for E398 or 6230......and now I have decided to go for the e398 soon.......
Meanwhile someone else has dumped me with his old Nokia 3595 which he won't be needing any more......so just wanted to know whether that can be used in India or not.
