Old 27-01-2006, 06:38 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Solution for Airtel GPRS users for PPP Error-
I am posting this solution because many ppl come across this common error and r not able to connect to the net using bluetooth and AIRTEL GPRS connection
(applicable only in case of Win XP pro. without the service pack 2)
Go to Control panel - phone and modem settings - Modems tab - select Bluetooth modem - advanced tab -
In extra initialization commands, type: AT+CGDCONT=1,"IP","airtelgprs.com","",0,0 (there are no spaces in between)
For dial up no. use - *99# or *99***1#
Always keep the User name and password field blank
If anyone knows wht "AT+CGDCONT=1,"IP","airtelgprs.com","",0,0" means, plz let me know
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Akshay is offline
Old 27-01-2006, 06:54 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Its the AT command for making the connection.
The format of this AT command is as follows:
AT+cgdcont=<cid>,<PDP_type>,<APN>,<PDP_addr>,"d_comp",<h_comp>
for example:
AT+cgdcont=1,�IP�,�test�,�10.10.10.10� ,0,0
Here the APN is the abbreviation of Access Ponit Name,usually it would be provided by the ISP.
Can't tell more than this
http://www.AskVG.com/
Vishal Gupta is offline
Old 29-01-2006, 12:41 PM   #3 (permalink)
deathvirus_me's Avatar
My Samsung X430 could dial *99# , *99*1**1# , *99***1# - *99***9# ..... while my Nokia 6630 and Nokia 6681 can dial only *99# and *99***1# .. and then my Motorola C650 can dial only *99***1# and *99***3# ... so i guess it depends upon the phone ....
AT commands are also not supported by many phones .. specially the older ones ... doesn't work on my Motorola C350 ....
deathvirus_me is offline
Old 01-02-2006, 06:18 PM   #4 (permalink)
is there any hack so that i can open other websites on Airtel Live (not Airtel GPRS)
(¨`·.·´¨)¸.·´ ~~~ ΛMRIT~~~
`·.¸.·´ <<< If you don't stand for something, you'll fall for everything >>>
__._,_.___
www.DillDosti.co.cc
www.DillDosti-Forum.co.cc
amritpal2489 is offline
Old 07-02-2006, 06:41 PM   #5 (permalink)
prasad_den's Avatar
Hi..,
I have tried the methods you have mentioned.. But I keep getting error messages like
Error 692: There was a hardware failure in the modem or other connecting device
or
Error 668 - The connection dropped
I've tried googling but to no avail...
prasad_den is offline
Old 08-02-2006, 03:09 PM   #6 (permalink)
same problem here.
but i always disconnect & then restart the system.
thats the i way i get rid of that problem. i very peculiar problem for all LG mobile phones.
Live Life King Size
Mangal Pandey is offline
Old 14-02-2006, 12:58 AM   #7 (permalink)
!FREEWARES!
Akshay's Avatar
restarting both the devices is d only solution. Also chk if u r within d bluetooth range. if u r using Win XP SP2, these kind of prb. keep coming up. Only solution den wud b reverting to SP1...
MBP 13.3";
Akshay is offline
Old 14-02-2006, 03:31 PM   #8 (permalink)
soham's Avatar
Originally Posted by Mangal Pandey
same problem here.
I too use a LG phone. Initially my phone too used to give a lot of trouble but now its become more stable. And the PPP error doesnot necessarily imply that u got some probs with ur phone or pc. Sometimes the error is shown when the server fails to respond to the request, I think it depends on the quality of service as well.
soham is offline
Old 04-03-2006, 11:53 AM   #9 (permalink)
svk
disable hardware flow control
Kind, intelligent, loving and hot.
This describes everything you are not.
svk is offline
Old 01-04-2006, 05:15 PM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
If ur airtel gprs suddenly stops working, just switch off ur cell, remove the sim, reinsert the sim and switch on ur cell. This technique seems to solve quite a few prbs.(reason for this is not known to me but it has helped me quite a few times) may be vishal can help us with the reason.
If this does not solve ur prb., reset ur cell to original factory settings (i hate this)
MBP 13.3";
Akshay is offline
