Old 27-01-2006, 02:16 PM   #1 (permalink)
Default Nokia 6230i or Motorola E398?
Which one is better?
subhranath is offline
Old 27-01-2006, 03:27 PM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
its like comparing fedora core 4 and red hat linux 7.3! e398 has excellant features..but is an old model. n6230i is better...
infra_red_dude is online now
Old 27-01-2006, 07:39 PM   #3 (permalink)
mobilegeek's Avatar
I will Go with Motorola E398
I think E398 is much better .. I dont like 6230i
E398 is available for 8.5-9k only
SD Cards compatibility .. so the exanpansion is not a problem .. even SD cards are not expensive
http://direct.motorola.com/ENA/web_p...roductid=29552
Even better is ROKR
http://direct.motorola.com/hellomoto/rokrbooth/
only if ... you can get ur hands on it ..
mobilegeek is offline
Old 27-01-2006, 08:34 PM   #4 (permalink)
Wire muncher!
well e398 doesn't haf stock video recording. thats reason why i used the similie or fedora core4 and redhat linux 7.3. you know that both linux flavours are good. its only that rhl 7.3 has become old tho it does its job very well! 6230i is a newer generation phone.
Old 28-01-2006, 01:48 AM   #5 (permalink)
mobilegeek's Avatar
FC4 is better thats true .. but Video recording of all phones are not upto the mark. As far as music is concerned, E398 has good output from loud speakers .. whereas 6230i has a mono loudspeaker, moreover 6230i also not a newly launched phone. Moto hasnt release any phone after E398, Rokr which was actually very hyped .. & they didnt release it in India.
Old 28-01-2006, 10:44 AM   #6 (permalink)
Wire muncher!
right...if you want value for money, a great onboard speaker sans video recording (not sure abt fm) then go in for e398. if you can afford 6230i go buy it!
Old 29-01-2006, 11:28 AM   #7 (permalink)
Go for Nokia 6230i. No doubt in it
There is a very fine line between genius and insanity. I have erased this line.
freezer is offline
Old 29-01-2006, 12:35 PM   #8 (permalink)
deathvirus_me's Avatar
Motorola E398 .... it has got very excellent feature ...
Video recording is not a problem ... a little flash enable's it ...
6230i vs E398
Well the 6230i definitely has some appealing features ... but then .. i think investing a few more bucks will fetch u a 6630 ....
The Motorola E398 is a really good value-for money phone .... U can also think about the Sony Ericsson K700i .....
If i were to choose a phone between the 6230i and the E398 ... i'll go for the E398 or i'll go and get myself the 6630 .. but not the 6230i ...
deathvirus_me is offline
Old 02-02-2006, 12:58 AM   #9 (permalink)
Does the E398 support SD cards?
Old 02-02-2006, 01:07 AM   #10 (permalink)
Wire muncher!
e398 supports transflash cards by sandisk.
Old 03-02-2006, 11:40 PM   #11 (permalink)
prasad_den's Avatar
It supports transflash card which is nothing but a mini SD card. A good phone other than its slow interface. Thats the only disadvantage.
prasad_den is offline
Old 08-02-2006, 06:35 PM   #12 (permalink)
montsa007's Avatar
well u can divert ur attention to nokia 6600 as they are all of same price categories
cheer$
montsa007 is offline
