Old 26-01-2006, 10:58 AM   #1 (permalink)
prasad_den's Avatar
Default Opera Mini error... :(
Hi guys,
I have a Moto E398. I have downloaded and installed the recent version of Opera Mini. But when I try to connect it says:
You do not have a working network connection. Please visit http://help.opera.com/mini/ with your desktop browser for instructions. (error: 3.0.10:80/).
I have the Airtel Net on Phone active.. I can browse sites through the default browser but am unable to use Opera..
Any suggestions or ideas???
prasad_den is offline
Old 26-01-2006, 11:25 AM   #2 (permalink)
deathvirus_me's Avatar
reinstall the browser form http://mini.opera.com/
deathvirus_me is offline
Old 26-01-2006, 11:43 AM   #3 (permalink)
prasad_den's Avatar
Any number of uninstallations and reinstallations don't work... So far tried 4 times... I think the problem is basically with the connection settings... I use the Airtel NOP for Rs.99/- a month...
Old 26-01-2006, 12:50 PM   #4 (permalink)
hi,
first u need to have gprs/wap connection. if u have airtel one connection. then u can see the configeration here http://www.thinkdigit.com/forum/viewtopic.php?t=35648 Change all the settings as i have mentioned. Sure it will work.
vamsee is offline
Old 27-01-2006, 12:09 AM   #5 (permalink)
dhan_shh's Avatar
You can try 'Low profile' instead of 'high profile' java file and you need both .jar & .jad.I've installed opera mini in my 9500 and it is not very good browser unless U have 3G.
Expect the Unexpected !
dhan_shh is offline
Old 27-01-2006, 01:00 PM   #6 (permalink)
I think this scheme covers only wap browsing via mobile ... .... full web browsing is for the 249 plan ....
Old 27-01-2006, 06:46 PM   #7 (permalink)
prasad_den's Avatar
Originally Posted by vamsee
hi,
I'm not sure if I have the Airtel One plan..and don't know what it is..!! I saw your other post, but have doubts 'coz my mobile doesn't have internet settings or profile settings for java... Can you clarify.. Thanks for the replies, though...
Old 29-01-2006, 11:52 AM   #8 (permalink)
java set r not there on ur mobile. dont worry thats for streaming and u dont hav that facility. be sure u have entered the settings correctly. it should work i browse forum in my mobile and also everything
vamsee is offline
Old 29-01-2006, 12:44 PM   #9 (permalink)
Look for "Web Sessions" ... u'll find different pre-defined settings here .... u must be currently using the Airtel GPRS session .... u can edit it ...
Why don't u call up the customer care ????
Old 31-01-2006, 03:42 PM   #10 (permalink)
QA Juggler
saROMan's Avatar
i too d/led the mini edition 2day..n not only its opening toooooo slow but i also gettin the same error.. i hav LG 1600 n iDEA GPRS........any help guys...???
saROMan is offline
Old 03-02-2006, 05:54 PM   #11 (permalink)
prasad_den's Avatar
Guys,
I got Opera Mini up and running...Had to do just a small change in the settings....Changed the connection type from Wap to Http. That's it..!!! Now I'm able to access the entire web..Sometimes I get a message that the connection is not correct but I just exit and restart Opera again and everything is okay...Thanks to all.....Especially to vamsee...
Old 19-02-2006, 03:50 PM   #12 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: Opera Mini error... :(
Originally Posted by prasad_den
Hi guys,
I have exactly the same problem. I tried different things as said in this thread, but i still cannot figure out How to do it . I even tried the vamsee's method but still no use. I request prasad_den to Please give details of how you solved this problem
Thanks
Charan
Charan is offline
Old 21-02-2006, 07:34 PM   #13 (permalink)
hi,
send me the network connection settings in detail mentioning the name and its options in detail. i will guide u. because i have done same thing for my frnds e398 and i can do urs unless u give me complete option set.
I guarentee u 1000%
vamsee is offline
Old 21-02-2006, 08:13 PM   #14 (permalink)
prasad_den's Avatar
Hi charangk and others,
If you have a Moto E398 and Airtel NOP, make the following settings:
Go to Menu - Web Access - Web Sessions - Airtel NOP ( or whatever it is you have stored the settings as or create a new setting).. Then edit the settings as follows:
Name: Anything you like
Homepage: -do-
service type I : http
Gateway IP I : 100.1.200.99
Port I : 9201
Domain I : leave blank
service type 2 : http
Gateway IP 2 : 000.000.000.000
Port 2: 8080
Domain 2 : leave blank
DNS I : leave blank
DNS 2 : leave blank
Timeout: 15 mins
CSD No I :leave blank
User Name I: leave blank
Password I: leave blank
Speed (Bps) I: 14400
Line Type I: ISDN
CSD No 2 :leave blank
User Name 2: leave blank
Password 2: leave blank
Speed (Bps) 2: 2400
Line Type 2: ISDN
GPRS APN : airtelwap.com
User Name : leave blank
Password : leave blank
Just make sure that this setting is your default web session..Then launch Opera Mini and enjoy.........!!!!
Old 21-02-2006, 10:35 PM   #15 (permalink)
Rubik's Uncle!!
Charan's Avatar
thanks a lot prasad_den. I will try it and get back .
Charan is offline
