Old 23-01-2006, 12:25 PM   #1 (permalink)
rajesh's Avatar
Default Area Info not displayed on K700i
I have a SE K700i mobile. It does not display the area information. I have a Hutch connection with GPRS not enabled.
DO I have to enable something in my Phone or does K700i does not display it?
Any help would be appreciated.
My Blogs
______________________
http://laughlines.rediffblogs.com
http://krrajesh.blogspot.com
rajesh is offline
Old 23-01-2006, 04:16 PM   #2 (permalink)
tuXian's Avatar
Well for Nokia Cell Info display needs to be turned on, plz check in the manual if you have such kinds function..... anyways one of my friends having K700 i and I will ask him about this and get back to you.
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 23-01-2006, 04:42 PM   #3 (permalink)
t3h g04t
teknoPhobia's Avatar
cell info display/cell broadcast receiving whichever is applicable has to be turned on, btw, if you have GPRS and have the always connected option on then you won't be able to get the area info
technologically challenged.
teknoPhobia is offline
Old 23-01-2006, 07:29 PM   #4 (permalink)
GOto Msg menu
msg settings
area info
set the option cell info on
it will work
get in touch
spidyweb is offline
Old 23-01-2006, 08:22 PM   #5 (permalink)
tuXian's Avatar
Well Rajesh my friend has sold his phone and didnt thought about all that coz he wasnt a tech type, try what tecknophobia says and update here
tuXian is offline
Old 23-01-2006, 08:22 PM   #6 (permalink)
rajesh's Avatar
Originally Posted by spidyweb
GOto Msg menu
msg settings
area info
it will work
Hey Spidy. Many thanks.. It worked. It took some time to appear, but is coming now.
Tks Once again.
My Blogs
rajesh is offline
Old 23-01-2006, 08:31 PM   #7 (permalink)
tuXian's Avatar
thats nice, thanks for updating
tuXian is offline
Old 23-01-2006, 10:22 PM   #8 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
I have SE k300i and I have already turned cell Info on but it still dont show the area info.
I have airtel prepaid connection.
My old nokia 1100 used to show area info on same connnection.
I dont know whats the problem?
n00b forever...
~Phenom~ is offline
Old 24-01-2006, 05:12 AM   #9 (permalink)
TechGuru#1's Avatar
It's a prob(generic) .....MAYBE with SE phones
I have got a SE750i.......& also with the same NO Area Info Problem!
In the same newtwork circle,my other Nokia phone shows the same info,but w/o any problem
TechGuru#1 is offline
Old 24-01-2006, 09:04 AM   #10 (permalink)
tuXian's Avatar
hey my friends Nokia suffers the same prob when he is at my place but mine works just fine.
tuXian is offline
Old 27-01-2006, 01:24 PM   #11 (permalink)
Asterisk enthusiast
abhasbajpai's Avatar
i hv se j200i but no problem with area info in most of the circle (i travel a lot in india) i use hutch
abhasbajpai is offline
Old 01-02-2006, 06:57 AM   #12 (permalink)
sidewinder's Avatar
Default Re: Area Info not displayed on K700i
Typically in SE phones the option to see area info lies under SMS or messege menu.U should find the option there
Bombina rocks
sidewinder is offline
