Old 22-01-2006, 11:53 PM   #1 (permalink)
Default expandale memory in nokia N70
CAN ANYBODY TELL ME THE EXACT / APPROXIMATE EXAPNDABLE MEMORY THAT CAN BE PLUGGED INTO NOKIA N70.
I KNOW THE PHONE COMES WITH 64MB EXPANDABLE MEMORY BUT JUST WANNA KNOW THE HIGHEST LIMIT OF ITS MEMORY CAPACITY
THANKS IN ADVANCE
kameyameya is offline
Old 23-01-2006, 12:09 AM   #2 (permalink)
18 Till I Die............
Do check it out on nokia's webiste. I can't seem to go the page so I can't offer you the link to the page.
http://www.bash.org/?258908
mehulved is offline
Old 01-02-2006, 03:27 PM   #3 (permalink)
montsa007's Avatar
128 is best above it the fone hangs a lot
montsa007 is offline
Old 01-02-2006, 05:59 PM   #4 (permalink)
Hangs above 128 mb card? Are u sure? Doesn't sound likely. If it is then that's too bad.
mehulved is offline
Old 02-02-2006, 08:39 AM   #5 (permalink)
mobilegeek's Avatar
Originally Posted by kameyameya
I know the phone comes with 64mb expandable memory but just wanna know the highest limit of its memory capacity
Thanks in advance
1GB works fine in N70 ... its the max that available in DV-RS-MMC
this the page .. for mmc mobile - kingston
http://www.ec.kingston.com/ecom/conf...1gb&referid=28
or
nokia europe site
http://www.europe.nokia.com/nokia/0,,84174,00.html
mobilegeek is offline
