here is the all info related to sony ericsson K750 firmware(I got it from
http://www.esato.com/board/viewtopic...=92737&start=0 )
R1AA008
- Released on SEUS for the W800 around 2/12/05.
- Released on SEUS for the K750 around 9/12/05.
- Fixes MS Duo file transfer issues from the PC to the phone over the supplied USB cable.
- Rotating and zooming into pictures displays an egg timer whilst processing.
- Menu navigation (particularly when displaying thumbnail images) feels faster.
- External speaker sound level increased
- Headphone sound level increased (by approximately 1 bar)
- Reduction of noise when playing low volume MP3s
- Center Weighted Average metering used instead of standard Average metering to improve photos in lower level lighting conditions.
- Further Contrast / Gamma modifications have been made to the display to improve screen image quality.
- BUG: Increased background noise during phone calls when the volume level is set to a low level.
- BUG: Some users are reporting occasional "incorrect parameter" error messages when transferring files from the phone to the PC. For some users, moving the USB cable to another USB port seems to fix the issue.
- PROBLEM: Zoom functionality does not work for images greater than 1632pixels wide and/or 1224pixels tall.
- JBenchmark 3D LQ: 201
- JBenchmark 3D HQ: 122
- JBenchmark 2: 330
- JBenchmark 1: 3814
- Software versions:
LCD 0
Camera 4.5
ITP CXC 125 932 R1D/E
R1NA005
- Released on SEUS for the W800 on 15/10/05.
- Improved battery life over R1N035.
- Fixes for low-tonal audio issues.
- Fixes for Bluetooth audio issues.
- BUG: MS Duo bug still present with this firmware. See the R1N035 entry for possible fixes.
R1N035
- Released on SEUS for the K750 on 12/9/05.
- Released on SEUS for the W800 on 7/10/05.
- Video bitrate improvements over R1L (as good as R1A044)
- Improvements to photo quality (less noise in dark photos, improved viewfinder refresh rate).
- Bluetooth stability improvements.
- Bluetooth security fixes - no longer asks for file confirmations with paired devices.
- Contrast / Gamma modifications have been made to the display for a better overall picture.
- Improved reception (the signal strength indicator tends to be higher than in previous firmwares).
- Increased MP3 volume.
- Backlight doesn't come on again to show time after phone locks.
- Popup menu icon in the WAP browser has been modified.
- Fixed "More" menu when adding addresses to an email message.
- Problem: Battery usage increased by around 20% following the improvements made to reception.
- BUG: (Fixed in the current revision B?) With some phones Java applications can no longer turn on Bluetooth (i.e. the message "Failed to complete this enquiry" appears rather than the question "Allow application to create server bluetooth connection?")
- BUG: Some phones experience MS Duo corruption after the firmware update. This seems to occur after transferring files over the supplied USB cable. Symptoms include erratic behaviour of the Media Player and problems with the file system such as corrupted or deleted files. Potential fixes are as follows:
- DUO FIX: Do not use the supplied USB cable to transfer files - use a USB memory card reader instead.
- DUO FIX: In Device Manager / Disk Drives select Properties on the Sony Eri Memory Stick and then "Optimize for Performance" on the Policies tab. You will now have to use the "Safely Remove Hardware" in the taskbar before unplugging the phone.
- DUO FIX: Format the memory stick in the phone and then perform a Master Reset / Reset All. Note that this will erase all settings - perform a full backup beforehand. This should be used as a last resort and does not necessarily fix the problem.
- JBenchmark 3D LQ - approx 204
- JBenchmark 3D HQ - approx 123
LCD 0
Camera 4.5
ITP CXC 125 932 R1E
R1N005
- Released by SETool on 30/6/05
- Test firmware for K750.
- Known bugs with this firmware
R1L002
- Released by DaVinci for the K750 on 22/6/05
- Released on SEUS for the K750 30/6/05
- Release firmware for the W800.
- Fixes the O2 GPRS issue introduced in R1J
- Video recording quality as R1J (i.e. inferior to firmwares previous to R1J)
- JBenchmark 1: 3880
- JBenchmark 2: 335
- JBenchmark 3D LQ - approx 201
- JBenchmark 3D HQ - approx 121
LCD 0
Camera 4.4
ITP CXC 125 932 R1B
R1K001
- W800 brown (pre-release) firmware
R1J002
- Released on SEUS 13/6/05
- Standby crash fixed / improved.
- Increased call and Media Player volume.
- Games menu operates much more smoothly.
- Smoother video playback
- General UI performance improvements
- Improvements and bug fixes to Bluetooth headset support.
- The auto focus beep sound has been changed.
- Saving a photo to the Memory Stick is now quicker.
- New MP3 folder on Memory stick
- Fixed the month names in the calendar for various european languages.
- Camera sounds are muted when in silent mode in some firmware locales (EU_1 , but not EU_3).
- Minimised Media Player icon changed.
- SMS 'to' text now black (previously white).
- A "Fully Charged" message is now displayed on screen when the phone has finished charging.
* PROBLEM: GPRS comms has been broken on many O2 phones and some phones from other service providers.
* PROBLEM: Video recording quality (bitrate) has been reduced.
- JBenchmark 1 - approx 3908
- JBenchmark 2 - approx 344
- JBenchmark 3D LQ - approx 205
- JBenchmark 3D HQ - approx 114
LCD 0
Camera 4.4
ITP CXC 125 932 R1B
R1C004
- Vodafone specific (K750 only)
- Released around 3/6/05
- No reported changes from R1A044
- As is the case with the K700, Vodaphone's R1C004 supports DRMed MP3s only.
LCD 0
Camera 3.8
ITP CXC 125 932 R1B
R1A044
- First release (K750 only)
- JBenchmark 1 - approx 3894
- JBenchmark 2 - approx 334
- JBenchmark 3D LQ - approx 131
- JBenchmark 3D HQ - approx 89
LCD 0
Camera 3.8
ITP CXC 125 932 R1B
To find out which firmware revision your phone currently has installed, perform the following:
Where < and > represents pushing the joystick left and right respectively.
Sony Ericsson Update Service
Your firmware can be updated through the Sony Ericsson Update Service II (SEUS II). In order to use SEUS you will need to have internet access (preferably Broadband) and attach your phone to your PC via the supplied USB cable.
Before installing SEUS you will need to download and install the following drivers:
Sony Ericsson D750/K750 USB drivers (K750 only)
Sony Ericsson W800 USB drivers (W800 only)
Sony Ericsson K750/D750/W800 Update Service USB driver
Follow the driver installation instructions carefully.
If you run into problems, you may wish to download and install Sun's Java Runtime Environment separately.
If the firmware update fails part way through, retry the SEUS. If the update consistently fails you will need to perform a Master Reset on your phone. It is likely that you will be required to perform a Reset All - a settings reset is unlikely to do the job. Do not forget to do a full backup of the contents of your phone beforehand - you will lose ALL your phone's data.
If you wish to check for updated firmware without reflashing your phone then, during the Download phase, check the "C:/Program Files/Sony Ericsson/Update Service/software-data" directory on your hard disk. The firmware revision is identified as the latter part of the filename. Cancelling the update during the download plase will not damage the phone.
