Results 1 to 7 of 7
Thread: dialing through pc
09-01-2006, 10:34 AM #1Right Off the Assembly Line
- Join Date
- Aug 2005
- Posts
- 45
dialing through pc
hello friends,
i just wanted to know if i can dial a number through my pc by connecting a mobile phone with modem to the pc.
i have connected my SE J300i to pc and tried dailing but it shows an error.
what should i do. plz help me.
bye...Speed is my passion and i trust 1000 Terahertz
09-01-2006, 12:58 PM #2
You cannot make any standard calls to ur friends . however you can make a csd or gprs call through ur pc to connect to the internet .
11-01-2006, 10:00 AM #3Right Off the Assembly Line
- Join Date
- Aug 2005
- Posts
- 45
How can that be done. Plz Explain.
Actually when i dial from my pc i get the connecting... message in my cell phone but it disconects after some time. I cant understand why.Speed is my passion and i trust 1000 Terahertz
16-01-2006, 12:33 PM #4
first check whether the letter G appears on ur cell . It is a symbol that u can use gprs . if it doesn't contact ur service provider . If it does and u acn browse the net on ur cell check that the modem drivers r installed on ur pc . If there is a problem u should get an error number . check the help for the error no.
16-01-2006, 12:33 PM #5
18-01-2006, 01:15 PM #6
u must hv got a cd wit ur cable ...so install drivers for modem from that of ur device....next install the sony ericsson software (manager, connection wizard, mms etc) in ur pc....then u need to setup ur internet connection from that se software....and connect...ur done...
ps:-
1> u may not need to install drivers as it wud be installed automatically wit d se s/w
2>warning: dont keep much expections for speed from that connection...No Pain...No Gain
19-01-2006, 11:19 AM #7Right Off the Assembly Line
- Join Date
- Nov 2005
- Posts
- 31
YES
u can make call via pc using ur mobile connecting softwares like fma http://fma.sourceforge.net you can do what all u want with mobile can be done by ur pc using serial or usb cable.
if u r asking via gprs connectivity u can not.
see towards left i do it that way
dialing bsnl bb from 2 pcs
By vicky_l7 in forum Broadband and DTHReplies: 2Last Post: 03-09-2009, 10:35 AM -
How 2 charge your phone dialing a 3 digit no.??
By ratedrsuperstar in forum Mobiles and TabletsReplies: 17Last Post: 25-06-2007, 06:20 PM -
[Modem Problem] No dialing.. Please help..
By //siddhartha// in forum NetworkingReplies: 11Last Post: 30-12-2006, 02:23 PM -
dialing using sify
By mohnishghodekar in forum QnA (read only)Replies: 1Last Post: 13-12-2005, 05:56 AM -
Dialing Problem
By uk_tyagi in forum Software Q&AReplies: 3Last Post: 08-12-2005, 06:37 AM
LinkBack URL
About LinkBacks
