Old 04-01-2006, 11:21 PM   #1 (permalink)
Default wireless internet..
presently i m thinking to get a wireless net solution...i guess ill go with airtel one as many ppl here suggestin.............but i want to know wht speed it offers...........also havin an edge phone is an advantage with the net??also do i need to ask for gprs net or edge net???? and whts the charge...it differes frm topic to topic..somone says 150 per month whereas some says 199 whereas some says 360...for unlimited........and somone says 10paise per 10kb(is it bit or byte) download.......also wht else do i need with handset????usb cable or data cable or some other device.....and wht is data card
magnet is offline
Old 04-01-2006, 11:40 PM   #2 (permalink)
mobilegeek's Avatar
Default Re: wireless internet..
You asked too many questions .. I answer these one by one ..
One solution is you get a broadband connection and put your whole house on wi-fi .. but ya it would be a little expensive affair
i will tell you about mobile gprs here..
...i guess ill go with airtel one as many ppl here suggestin.............but i want to know wht speed it offers...........also havin an edge phone is an advantage with the net??..
Yes with EDGE you will get double/more than the regular GPRS speeds
Depending upon the phone & network too.
Ask --> MOBILE OFFICE & Settings too.
You need to call 121 from Airtel mobile or 9810012345 or the no. in your area
or Contact any nearby AirTel Outlet for exactly ..
you gonna pay .. as per your Bill Plan
For exact charges just contact the customer care
You will have to connect the phone to your computer
Datacable or Bluetooth whatever your phone support
Data card fits into the laptop .. and contains a SIM Card just like your phone has .. it just that .. It replaces the need of the cell phone .. but expensiv
Better for you to try this with cellphone only
mobilegeek is offline
Old 04-01-2006, 11:59 PM   #3 (permalink)
speedyguy's Avatar
well gprs rates vary from places dude so u gotta checkout wats urs....for eg. its 99/mnth in maharashtra n rs. 5/day in bihar/jharkhand...so gud luk
cheers
No Pain...No Gain
speedyguy is offline
Old 05-01-2006, 12:33 AM   #4 (permalink)
first thks for replying.......next...i stay in mumbai.....
wht does this means
but are the facts abt unlimited usage per day charge true...or its jus for mobile.......will i be able to use it on my pc.........
now say i got a 6630 fone..it supports edge technology......now i want this wireless net...than wht shd i ask.....gprs net or edge net(does this term exist).............also 1 guy suggested me that gprs net sucks.......
magnet is offline
Old 05-01-2006, 01:21 AM   #5 (permalink)
mobilegeek's Avatar
Such terms doesnt exist .. Just two one for downloading only ringtones n wallpapers
& The full gprs is called MOBILE OFFICE ..
e.g.If the provider is providing the EDGE .. then you can use EDGE too..
And
For the rates .. In Delhi we got 499 p.m. for unlimited usage .. you can use on computer
So .. you have to see what they are charging in Mumbai .. I think it should be same there too
Regards
mobilegeek
Old 05-01-2006, 08:32 PM   #6 (permalink)
fine now some of ending queries...........
suppose i have a lappy how do i connect the phone+data cable+wht????
lan card or pcmcia card???????
also can the phone be connected by bluetooth or wht....
and someone who has used net like this give the max download speed the person got in kB(kilobytes)...and ofcourse in india.....
also can i use the same net on pc??? and wht interface with pc need to b used???lan card..or usb lan card will do...or some other card?????
also how does it differ frm wifi?????
magnet is offline
Old 05-01-2006, 10:31 PM   #7 (permalink)
speedyguy's Avatar
well magnet lemme get things clear for u...
u just need to call customer care (121) from ur handset....n request for activating "mobile office" service....
since u in mumbai, twill charge u Rs. 5/day
ps: (im using airtel gprs in nagpur-studing n jamshedpur-home)
now u need to get a usb data cable for nokia...connect it to ur usb port ....install mobile softwares provided wit ur data cable....
ps:- also can hv serial cable but i dun recon u..its oldie now
setup an internet connection for airtel gprs....dial it 2 connect n u can surf in ur pc via mobile
well i get download speeds abt 4-6kbps(without edge)....but its not consistant...breaks up often in day times
u cant use it as ur primary net connection...can just keep it as alternative or backup....n u can also browse wap sites within ur cell to download ringtones, games, wallpapers etc.
pm me if u have any querries...im facing all this infact rite now surfing through this gprs.
cheers
No Pain...No Gain
Old 05-01-2006, 11:25 PM   #8 (permalink)
mobilegeek's Avatar
I use that too .. .. in Delhi .. 7-8KB avg & 12-14KB max bcoz of EDGE
For installing .. just dowbnload the latest version of pc suite and connct phone by Datacable .. make a New Connection.
For specific settings & Tariff you have to CALL 121 from your cell.
Old 06-01-2006, 07:32 AM   #9 (permalink)
will the phone remain busy while using net????jus lik dial up????
and wht abt the card??any special cardneeded for lappy and pc or wht???
magnet is offline
Old 06-01-2006, 07:35 AM   #10 (permalink)
mobilegeek's Avatar
You can recieve calls
Old 06-01-2006, 04:15 PM   #11 (permalink)
speedyguy's Avatar
no nothing extra required...just d cable n ur done
cheers
No Pain...No Gain
Old 06-01-2006, 10:06 PM   #12 (permalink)
rs 99 r u sure...i can use the same for pc?????
somone says rs 600(for something ard 8-13kBps...phone using edge).....whereas alot of place ppl suggest there customer care sucks...thats why i m asking lot of question here.....i will go to airtel gallery in a day or 2......
also bluetooth dongle will do or wht???
magnet is offline
Old 06-01-2006, 11:56 PM   #13 (permalink)
mobilegeek's Avatar
magnet
.. BT also works .. just dont forget to install the latest PC Suite First .. Bcoz it also installs the modem drivers.
Data rates Depends on the Network Provider
& Nokia phones can have a speed
in EDGE - Maximum download 236.8kbps; upload 118.4kbps
For .. Charges you have to contact tha Local AirTel Office
We cant tell you charges .. they depend on the tariff and plan you are using
Old 07-01-2006, 09:39 PM   #14 (permalink)
hutch says they giv lappy net for 499.....and that too at 10kb/10paise download rates......now will call airtel tomm
magnet is offline
Old 07-01-2006, 10:14 PM   #15 (permalink)
speedyguy's Avatar
i can be 99% sure its rs. 99 for u in gprs....n yes u can use it in ur pc or lappy...though speed just isnt gud enuf....better get airtel broadband...pretty gud....a bit costly round 700-800rs/mnth but unlimited download..so if u a net savvy...can get one....and always look for unlimited downloads offer...billings sometimes screw u up...carefull wit dataOne n others....gud luk
cheers
No Pain...No Gain
Old 07-01-2006, 11:21 PM   #16 (permalink)
speed u talking abt which net???mobile net..or broadband???...since xcept my service provider hathway..no one accesses my building xcept shity sify
magnet is offline
Old 08-01-2006, 01:41 AM   #17 (permalink)
speedyguy's Avatar
was talking abt airtel mobile internet regarding 99/mnth n not so gud download speed....
thers airtel broadband which is better but its not via mobile n not available everywhere.
cheers
No Pain...No Gain
Old 09-01-2006, 06:21 PM   #18 (permalink)
montsa007's Avatar
why don u get the airtel wireless datacard?even reliance offers 1
montsa007 is offline
Old 09-01-2006, 07:19 PM   #19 (permalink)
speedyguy's Avatar
hi again montsa...u took my attention again....can u plz explain abt wat u saying...thanx
(or pm me)
cheers
No Pain...No Gain
Old 09-01-2006, 09:45 PM   #20 (permalink)
airtel data card is mentioned on its site....airtel.......but there is download limit on it...and u need pcmcia card...........which is ard 12k i guess
magnet is offline
Old 09-01-2006, 10:20 PM   #21 (permalink)
speedyguy's Avatar
no wez...will never go wit a limited connection....n wat abt reliance...which is d best networking provider in mobile networks....considering speed n rates?
cheers
No Pain...No Gain
Old 10-01-2006, 02:08 AM   #22 (permalink)
mobilegeek's Avatar
Right man.. Thats why I said its expensive ... Its better to use the a EDGE phone instead
Old 10-01-2006, 09:01 PM   #23 (permalink)
speedyguy's Avatar
is edge wit mobile office considerable regarding download speeds n consistancy? or is there any other network in india better? im using airtel without edge(SE)....n its hell...i may kill myself
cheers
No Pain...No Gain
Old 10-01-2006, 10:48 PM   #24 (permalink)
the confusion frm my side is....i also m confuse...some ppl here say..u activate gprs and mobile office...and if u have edge phone..... speed increases...which confuses me...because some says airtel provides edge net.......
will try to contact airtel soon
magnet is offline
Old 13-01-2006, 02:31 PM   #25 (permalink)
mobilegeek's Avatar
You can get good speeds
.. when both of these condition are fullfiled:
1. You have compatible handset
2. The provider is giving you the full bandwith in your area
So ask AirTel
Old 13-01-2006, 02:44 PM   #26 (permalink)
speedyguy's Avatar
i say it again airtel sux in my area atleast....speeds r decent but there r very frequent break-ups so kinda downloading is not consistant....all in all it degrades its service n speeds. im still finding a solution for it.
cheers
No Pain...No Gain
Old 13-01-2006, 03:56 PM   #27 (permalink)
mobilegeek's Avatar
yaar why are you saying this again & again ..
AirTel Jamshedpur .. is the problem .. if they are not giving you EDGE there ..
you can only get good speeds .. If & only If AirTel Jamshedpur .. installs the better setup
try If Hutch has installed EDGe there .. that will be better option for you
Old 13-01-2006, 04:24 PM   #28 (permalink)
speedyguy's Avatar
well hutch is not available in here....dunno whether airtel here supports edge may be somene from jsr wud only help....hey 1 more thing is
using reget deluxe in this connection downloads are much more consistant wit 4-6kbps (generally...som times little slower)....so i mean if reget can make download more consistant there shud be any other s/w for optimising browsing speed...i know there r tons of em but anybody experienced wit a kool one plz suggest or else theres just arrived a saral broadband...unlimited...shud be gud
cheers
No Pain...No Gain
Old 21-01-2006, 11:25 PM   #29 (permalink)
i got my hutch www service activated and all works well the PC suite detects my phone and is able to connect to the net via USB cable at 480kbps speed i am getting download speeds around 20KB/sec but now the only drawback is i am unable to receive calls,,,, is there a software that could help me,,, or do i have to change some settings???i am using a Nokia 6630 please help me
fighting for peace is like ****ing for virginity
cryptid is offline
