Old 01-01-2006, 06:50 PM   #1 (permalink)
~[::BOoYaKa::]~
Default !DEA GPRS URGENT HELP!!!
does anyone here use idea gprs?? if yes then pls tell me how to activate the gprs!!!
i have a prepaid connection, but when i call cust care to activate gprs, they say that gprs is not available on prepaid, but idea's website says that its available on both prepaid and postpaid!
if ne1 use gprs on prepaid then plz tell me!!
Thank you very much!
REY!
[::Eddie n Benoit Live Forever::]
REY619 is offline
Old 01-01-2006, 08:17 PM   #2 (permalink)
Friend actually what happens is that gprs in prepaid is avail in some region while it is not avail in other regions,so may be u lie in a region where they don't provide gprs.So both the website and the Cust care r right.
Najesh is offline
Old 01-01-2006, 08:40 PM   #3 (permalink)
Searching...
Ya !dea does provide GPRS now for both prepaid and postpaid. Few days ago only my friend activated that. For that you will have to download the settings for your phone from the network by sending an SMS to 4444 sorry i don remember what exactly you should send but its something like GPRS followed by your cell model no. The service will be activated in 48 hours and you will be charged 2 paise per KB for browsing. NO monthly rental.
Dell Studio 15 -- Core 2 Duo T6400 , 3GB DDR 2 800MHz RAM, 320 GB, ATI Raedon HD 3400 256 MB Graphics Card, 15.4" WLED display, 8x DVD writer, Bluetooth Mouse, WiFi, Ruby Red Color, Creative EP-630
amol48 is offline
Old 02-01-2006, 06:43 PM   #4 (permalink)
~[::BOoYaKa::]~
yeah i have tried that also!
i had sent the msg for the settings and recieve the settings also and activated the settings and still when i try to create connection, it says "subscribe to GPRS first!!" dunno wats happening!!!
REY619 is offline
Old 02-01-2006, 08:31 PM   #5 (permalink)
Searching...
When did you send this msg. Give 48 hours at least for the service to start. If its more then do this ! in the connection settings select make GPRS "when available". Then if you see the G icon on the main screen of your phone it means that your GPRS is active and the problem may be with your phone settings. In that case i would suggest you personally go to the cuctomer care office for the settings. I will be definately done!
amol48 is offline
Old 03-01-2006, 07:22 PM   #6 (permalink)
~[::BOoYaKa::]~
yup i have waited more than 48 hrs!
ok i will try dat also!!!
REY619 is offline
Old 06-01-2006, 10:13 PM   #7 (permalink)
instead of all this circus y dont u get a airtel prepaiddaily rental is Rs. 5/- for unlimited browsing & downloading. as far gprs setteings are concerned the cust. care exec. will give u activate in 4 hrs. moreover u can use the use exclusively 2 use 2 connect through gprs.
Live Life King Size
Mangal Pandey is offline
