Old 17-12-2005, 02:59 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Corrupt real player in n6600
All of sudden real player on my n6600 is not working... If I choose to play any .3gp file, it returns error "unable to play clip" or "unable to play either audio or video. Try playing partially". I have smart movie and wmaplus installed. They are working fine.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 18-12-2005, 01:00 AM   #2 (permalink)
dhan_shh's Avatar
Some .rm files show similar errors in 6600.Take a nine seconds video clip using 6600 and try to play it.If still NOT working U need to format ur phone,soft format *#7370# and code 12345 (after taking a complete backup).
Expect the Unexpected !
dhan_shh is offline
Old 18-12-2005, 05:23 PM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
Default Other sol?
is there no other sol like adding a file or modifying them or installing any alternate real player or updating current real player? Even recorded clips dont work. Only sound plays... I dont want to format my phone...
MBP 13.3";
Akshay is offline
Old 18-12-2005, 05:29 PM   #4 (permalink)
mobilegeek's Avatar
Whats the problem in formatting .. just save the contacts
dont worry .. it will resets the phone to factory setting .. n can solve many problems ..
Dude there is no harm in doin that .. your phone will work better after that
Regards
mobilegeek
mobilegeek is offline
Old 18-12-2005, 05:40 PM   #5 (permalink)
!FREEWARES!
Akshay's Avatar
Default formatting...
and what abt messages, notes, to do n calender entries? Will they be deleted too?
MBP 13.3";
Akshay is offline
Old 18-12-2005, 05:50 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
U can try using Helix Player.Is's open source and uses the same code base as Real player.
dIgItaL_BrAt is offline
Old 18-12-2005, 06:14 PM   #7 (permalink)
mobilegeek's Avatar
But the problem with the phone must be fixed dude ..
Old 22-12-2005, 03:08 AM   #8 (permalink)
yes it will be.U can find it at the HelixCommunity site.
Old 22-12-2005, 01:20 PM   #9 (permalink)
mobilegeek's Avatar
Default Re: formatting...
If are worried about that .. take back up
Go to Organiser>Memory Card then Options>Phone memory backup
after doin the Reset of the phone
then again Organiser>Memory Card then Options>Restore the phone memory
Thats it
Old 24-12-2005, 08:46 PM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
I tried using *#7780# but real player still couldnt play 3gp files. So I clean formatted using *#7370# and now my cell is working fine... better than b4. I used contact transfer s/w. available for free on net for backing up my phonebook. I had earlier taken a backup on my mmc. But on restore, real player again started giving prb. So I had to format mmc too. But it was worth it...
MBP 13.3";
Akshay is offline
Old 25-12-2005, 01:26 AM   #11 (permalink)
mobilegeek's Avatar
ok .. good ... all is well.
