Ok .. Here I go
Buy 6630 .. Its a real steal at 13500 bucks
as for 6681 .. this phone sucks ... keypad not so good, on looks too .. its down, & no 3G
Do Remember that .. 3G is comin in no-time
So .. for this budget 6630 is a good buy
& Spend 1200 more you get the FM ready
If you want to extent the budget buy N-70
.. then you will get FM Radio, n Flash as add-on + 2MP Camera
Incase you dont want a smart phone ... Buy SE - K750i
Its a sexy multimedia phone, + you will get a FM & 2MP Camera
+ Flash
So, the conclusion is:-
If you like to install SW, want a smartphone = Nokia 6630
If you dont want the SW, n Want to have a Cool Black multimedia phone = SE - K750i
If you can increase the budget, you can get both in one = Nokia N70
Regards
.....mobilegeek
