Old 09-12-2005, 08:55 AM   #1 (permalink)
vimalonline
Posts: n/a
Default Data Cable for 6600
hi
i want to know whether Nokia 6600 supports data cable..
Pls mention the type of data cable also..
Old 09-12-2005, 04:17 PM   #2 (permalink)
6600 does not supports data cable, use Bluetooth/IR instead
Think Once, Think Twice, Think Grace
Grace is offline
Old 09-12-2005, 05:26 PM   #3 (permalink)
dhan_shh's Avatar
Visit this link:
http://cgi.ebay.in/USB-DATA-CABLE-fo...QQcmdZViewItem
Expect the Unexpected !
dhan_shh is offline
Old 09-12-2005, 10:05 PM   #4 (permalink)
dIgItaL_BrAt's Avatar
that link is just a scam,where the hell r u going to connect it?.The Nokia 6600 does'nt even support the Pop-Port interface.
dIgItaL_BrAt is offline
Old 10-12-2005, 12:21 AM   #5 (permalink)
dhan_shh's Avatar
Hi Hi,don't jump to conclusion,I've used cable for 6600 15months back itself.U hv to remove the battery and put the Cable one end and USB end to PC.It doesn't require PC suite.It is recognized as removable disk by PC.
ONLY problem is everytime we have to remove the back panel and battery,otherwise it is reasonably faster.
dhan_shh is offline
Old 10-12-2005, 12:28 AM   #6 (permalink)
dhan_shh's Avatar
Look at the picture in the link,this is how battery compartment is connected:
http://cgi.ebay.in/NOKIA-6600-DATA-C...QQcmdZViewItem
dhan_shh is offline
Old 10-12-2005, 12:48 AM   #7 (permalink)
Your first link showed a data cable with a Pop-Port connector.
Old 12-12-2005, 05:52 PM   #8 (permalink)
vimalonline
Posts: n/a
Default Re: Data Cable for 6600
Originally Posted by vimalonline
hi
hi,
i got the info frm nokia ppl that 6600 wont support datacable
Old 16-12-2005, 01:47 PM   #9 (permalink)
hey dhan is right............. that battery removing thing works.............. i hav seen my friend connecting is 3315 to his pc bt that trick........... just do some research on that........ and u'll get to know the trick............ or else go for a bluetooth dongle or ir
satbir is offline
Old 16-12-2005, 08:47 PM   #10 (permalink)
mAYHEM's Avatar
N6600 doesn't have Pop-Port so it doesn't support Nokias DKU-2 cable,so u will not be able to use Nokia PC-Suite.Go for Bluetooth.
Lenovo Y570|eMachines EM350|iPad2 (3G)|iPod (80GB & 160 GB) |Galaxy S2|Galaxy Note|Storm 9500|Nokia 8800|Shure SE535|Sennheiser CX 500.
http://www.speedtest.net/result/445135884.png
mAYHEM is offline
Old 18-12-2005, 08:37 PM   #11 (permalink)
i would suggest u to use memory card reader which will cost u 450 rupees(chinese version) . it is faster in reading and writing than bluetooth or infrared. it can not only read and write mobile memory cards but cards frm other devices like digital cameras also.
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
