Hi
To connect your phone to PC using IR you need Nokia PC suite for 6610i.
If you already haven't then install IR drivers.
Then you need to keep your phone in line with IR to connect with IR turned ON on your cell. Then you can use the different softwares in PC suite for images and ringtones.
AFAICR, you can only use polyphonic rongtones for 6610i, so you'd need midi files for that.
Well for midis just do a search on google. I had a site where there were many midis of english songs but I have lost it.
I don't have my bookmarks handy at the moment but whenever I have them I will post it.
http://www.bash.org/?258908
