| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
#2 (permalink) |
Commander in Chief
For primarily s/w i wud recommend Bluetooth coz u dont have to rip off the cover and remove the MMC card always to do a thing.
Also, for backup, etc... if u can get a Cable its much better and faster though i dont recommend a card reader unless u have a digicam or other stuff that can use it too...
Harsh J www.harshj.com |
#3 (permalink) |
Wire muncher!
ok wid a bluetooth you can do all things that ur phone supports. you can even control ur computer wid it. but compared to card reader, it does haf some hassels.
but in case of a card reader, its just too easy to work wid it! simplicity matters!
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#4 (permalink) |
but hassles r much higher with bluetooth.
the 1 good reason 2 use bluetooth is if u want to use the fax modem option. i had 2 buy 3 bluetooth dongles 1 after other. i also hv 3230 .now usin card reader frm tech com. i good thing is card reader is quite versatile.
longing for 7800gtx |
#7 (permalink) |
18 Till I Die............
Bluetooth seems a better idea as the RS-MMC card in 3230 is not hot swappable. So, you'd have to remove the card to use with card reader whereas for bluetooth you just need to connect.
As for hassles I don't think there's too much hassle. You just need to install bluetooth's updated drivers , nokia PC suite and connect. Its not too tough. And IMO bluetooth offers more options.
http://www.bash.org/?258908 |
#10 (permalink) |
Transfering music files...or any large file using bluetooth will definetly take a longer time!
But thats not the case with a card reader...u jus hav to insert the card and its a typical drag n drop feature! Pretty easy man...u can hav more files transfered in a easier manner... A card reader(16 in 1) wud cost around 350bucks... as tech_your_future said: Disadv: 3230 is NOT hot swappable! decision is ur choice.... |
#11 (permalink) | |
For the 1s, which are under the battery/for which u hav to switch off.. to take ur card out...is NOT hot swap. |
#12 (permalink) |
the card is def hot swappable, but u hv 2 open the back panel cover.
the other thing is installin software is much easier and faster by card reader as by bluetooth every thing comes in inbox 1st then gets installed in mem card. while card reader u can put it ne folder u want before u install the app |
#13 (permalink) |
Hi guys I have both I just purchased one card reader as cant transfer large files using bluetooth as my phone has only 4mb internal memory N-Gage. Now my problem, after I plugde card reader in my usb XP detected and installed drivers automatically n was able to transfer all the data from card to pc in seconds but problem started when I tried to copy files from pc to card I receive a error message unable to perform operation drive is write protected I checked 2 card but same prob I also tried to change read only option but no luck I formatted card but in vain also checked if any option in phone but none. Can anyone help for same y I m unable to write delete data using card reader.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
