| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#5 (permalink) |
My Blue tooth dongle i got for 425 in chennai with cd and usb cable....
Company: Prodigy Regards...
Intel Pentium 4 2.40C @ 800 Mhz FSB,On Asrock P4i65GV, 1 GB Transcend DDR 400 Mhz,160 GB Seagate SATA,120 GB Samsung PATA GeForce FX5500 256MB,LG GCE-8525B,52x32x52x,Lite-On SOHW-1633S DVD Burner Creative 2.1 Inspire Series,Syncmaster 17\" 793MB |
#6 (permalink) |
18 Till I Die............
I got a software cd with the bluetooth dongle.
No USB wire. Why would u need it? u just have to connect the bluetooth dongle to ur computer's USB port. I do not know the company's name which has manufactured the dongle but its bundled with IVT Bluesoleil's software which will work with nokia phones without problems as it is one of the recommended drivers by nokia. But, IMO you might have to download the latest drivers from http://www.ivtcorporation.com/downlo...l_Download.php to work with PC suite.
http://www.bash.org/?258908 |
#8 (permalink) |
@pandahk What do you mean by 'including USB cable'?
You don't need any USB cable for connecting via bluetooth. You just have to pop the Bluetooth dongle in the USB port of your computer.
#9 (permalink) | |
I bought one last week for 400. CD + Dongle.
Sometime you'll think you understand everything ...Then you'll regain consciousness |
#14 (permalink) |
Technoholik !!
I bought one for 800. Dongle by ENTER.
Package included one IVT Blue Soleil Driver CD and no cables I don't understand what the hell the Wire/Cable will do with Bluetooth Dongle. A Bluetooth Dongle allows you to have your devices 10 MTs apart. So you can control your PC from the Sofa itself. |
#15 (permalink) |
Wire muncher!
no buddy, many time it happens that the usb port location is a bit awkward or other devices may hamper the dongle to fit in. in such cases a usb extension cable is very helpful.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#16 (permalink) | |
#17 (permalink) |
Yeah infra_red_dude what you say makes sense but I'm yet to see this kind of problem anyhwere considering the bluetooth dongle isn't much bigger than the head of USB cable.
#18 (permalink) |
Wire muncher!
naah... its happend wid me. the usb port on my lappy is just too close to the combo drive. if i plug in any device the tray just can't be opened. tho i haf 2 more ports, they are usually connectoed to some devices. i used to use an extension cable wid the dongle. also many a time when i keep the lappy wid the usb dongle plugged in onto this port (which hapns to be located on the right side) on my bed, due to uneven surface the dongle is liable to get damaged. an extension is very helpful in such cases.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
