| Forum |
| Mobiles and Tablets Topics related to mobile phones, tablets and various operating systems. News should also be posted here. Note: This NOT the place for BUYING ADVICE queries. |
#1 (permalink) |
Distinguished Member
i am able to send and receive single files from my pc (winxp/sp2) to my nokia 6600. but i am unable to backup my contacts or my fotos/clips together in one operation. how do i do it ? my fons name is 'Nokia 6600'. i have installed the nokia6600 pc suite which came with my celfon and the bluetooth dongle too, along with their respective softwares. as mentioned, ven i rtclick on a file on my pc, i can thru : send to >bluetooth file transfer wizard, send/receive a file. but in 'my blooth places/bluetooth configuration', when i click, it says 'no blueooth devices found' ! so in control panel itself, ven i clicked on bluetooth devices, in 'phone and modems' it shows my fon 'nokia 6600'. ven i start the nokia pc suite, rt click on its logo in the system tray > connect to bluetooth device, it detects my celfon, and states already connected. so ven i click on ok, after sometime i get the message "failed to connect to nokia 6600 - a socket operation failed because the destination host was down". also ven i click 'nokia connection manager', and rt-click on its logo in the pc system tray, i open connection manager. a window opens and here it says no fon connected. so ven i click on the 'bluetooth connection' logo, i get the msg "media type not supported. check your systems for media settings". so what seems 2 b the problem ? perhaps some required services of my winxp is disabled !? what shud i check up ? what shud i do ?
> www.TheWindowsClub.com < = www.WinVistaClub.com = Microsoft® MVP |
#2 (permalink) |
18 Till I Die............
Firstly, do you have the latest drivers for the bluetooth cos in my case I had problems with PC suite cos of outdated drivers. So, updated drivers will help. And the latest PC suite too if you can download it from nokia site. I too had a same problem with PC suite for 6600 but PC suite for my sister's 3230 worked fine but only after updating the drivers. Never tried PC suite for 6600 after that.
http://www.bash.org/?258908 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
