Old 06-11-2005, 10:36 PM   #1 (permalink)
xpabhi's Avatar
Default Usin net thru ur Mobile
Hey guys.....
ONCE UPON A TIME i saw this post which dealt with how to connect an EDGE enabled mobile to ur PC n use net thru the plans tht Airtel or hutch provide...... it also had tariff plans...speeds n stuff
i searched for it ovr n hour today
cudnt find it anywhere.......must hav overlooked or somethin.... cud somebody jst give me the link to tht post or tell me how to do it!
thanx
take care
Better to burn out, than to fade away!
xpabhi is offline
Old 07-11-2005, 12:12 AM   #2 (permalink)
A GPRS connection is enough to browse net thru your phone. I've used the Airtel connection for months now.
Firsty you need to install the modem driver for your phone. If its a bluetooth compatible (which it would be) then the XP automatically detects the phone modem.
Next you need to create a new dial up connection with the modem over bluetooth link (or something similar) as your dial up device. For Airtel the phone number to dial is *99#. It ought to be the same number for Hutch too. Password can be left blank for Airtel.
Dial and enjoy!
LordDJ is offline
Old 09-11-2005, 10:51 PM   #3 (permalink)
xpabhi's Avatar
umm...thanx!
xpabhi is offline
Old 10-11-2005, 12:04 AM   #4 (permalink)
choudang's Avatar
Default Re: Usin net thru ur Mobile
first thing you have to know that, for EDGE, your service provider should provide you the EDGE feature, u can't use by urself.
i agree with that, but some cases its not. if you are using some Bluetooth dongle, XP won't take the driver automatically. you have to manually install the driver from the CD that provided with BT. i had that exp with N-gage QD.
if you use Nokia PC suite, don't have to create dial-up connection. you can do it from main menu directly. but i preffer to create dial-up where you can increase the connection speed upto 900 kbps [but true fact is that GPRS provides 14.3 kbps without EDGE] as i'm using the GPRS the dial number [airtel] is *99***1#, user name : mobile no pass: [blank]
choudang is offline
Old 24-11-2005, 12:36 AM   #5 (permalink)
xpabhi's Avatar
hey Warrior tel me somethin
no offense....but wt do u or rather how can u manage with 14.3 k'b'ps...now tht sux...doesnt it!!!
xpabhi is offline
Old 25-11-2005, 12:27 PM   #6 (permalink)
choudang's Avatar
for me.. its ok ... cuz all the pages are opend up as usual. i got upto [startting] 40kbps download speed which stucks ate 3 kbps [normal download] and have got upto 12kbps using IDman.
but when i use IE, it sux, but using Flock.. its rocking
choudang is offline
