Old 04-11-2005, 12:19 PM   #1 (permalink)
aryayush's Avatar
Default How to reduce the size of an MP3?
Hello!
I recently bought a Sony Ericsson W550i Walkman and it is a great phone and very very appropriately priced. However, the most major drawback that it has is that it does not support expandable memory.
Therefore, I want to make good use of the 256 MB provided. Can you guys please suggest a good method of reducing the size of MP3s? And how much quality will be lost in the process, if any?
Thanks!
aryayush is offline
Old 04-11-2005, 03:57 PM   #2 (permalink)
Using any mp3 encoder rip the songs from cds or
convert others to this format:
Format: Mp3 CBR
Bitrate: 64 Kbps
SampleRate: 22.050 KHz
Channels: Sterio
Sterio Mode: Joint Stereo
It will give you a fair quality with very less file size.
vishalbhatia is offline
Old 04-11-2005, 07:03 PM   #3 (permalink)
gxsaurav
Posts: n/a
don't use mp3 anymore for playback on mobile phones
insted use either Nero or dBPoweramp to convert the mp3 to mp4 files, although the quality is subjective, U will be able to get the quality of 128 kbps mp3 by a 80 kbps mp4, or even 64 kbps in some cases, but keep the sample rate at 44.1 KHz
if u r using nero, then make sure U disable the AAC flag, also check with difference which setting gives u the best quality
Old 05-11-2005, 04:37 AM   #4 (permalink)
mobilegeek's Avatar
gxsaurav Very true .. mp4 is better to use on mobiles, .ogg is even better but It will not run on W800i (correct me if I am wrong).. So .. convert to mp4 format 64kbps at 44.1 KHz
mobilegeek is offline
Old 06-11-2005, 10:50 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
btw w550i supports aac. try that format.
use this software (dietmp3) to slim ur mp3s:
http://www.winsite.com/bin/Info?5000000037130
it does the same thing as dbpoweramp but the interface is very user friendly.
infra_red_dude is online now
Old 08-11-2005, 12:43 PM   #6 (permalink)
Default Need Information for nokia 6670
i just bought nokia 6670 and i have 256 mb mmc card now i want to load ong into it o tell me how to do it & also how to convert large size songs into small,also can somebody provide antivirus s/ws.
Commitment-->Character-->Value-->Action
Success is Progressive Realisation of a worthwhile Dream.
Success is Always a choice between 2 things-- To Do or Not To Do.
fenil_4400 is offline
Old 08-11-2005, 10:37 PM   #7 (permalink)
For the anti virus...u can use:
Fsecure Anti-virus .... www.F-Secure.com <http://www.F-Secure.com>
As for the large mp3 files...u can convert the rate of the song to 96kbps or 64kbps. This wud do. It wud reduce a 4mb file to 3mb and 2mb resp. The conversion can be done using music match jukebox (its given in one of the digit cds few issues back). also its free...
Or any other simple convertor wud do....
prash007 is offline
Old 09-11-2005, 08:55 PM   #8 (permalink)
Default Re: Need Information for nokia 6670
Well 6670 comes with bundled Anti-Virus application from F-Secure.
Download free from their official site. Just follow the link below:
http://mobile.f-secure.com/nokia/6670/
Old 30-05-2006, 12:14 PM   #9 (permalink)
aryayush's Avatar
Default Re: How to reduce the size of an MP3?
The WALKMAN application in the SE WALKMAN PHONES only recognises MP3 and AAC files as audio files. MP4 files are recognised as video files.
Which software will help me convert files to the AAC format?
aryayush is offline
Old 30-05-2006, 03:12 PM   #10 (permalink)
Quality will decrease if u convert it into mp4.
Najesh is offline
